Should I be using a fuel addative in my 7.3?
Fuel is required to meet a minimum lubrication standard, the standard has been the same forever, despite the sulfer being taken out. They add lubricants to fuel now to meet the requirements.
I for 1 have rarely ever use additives and ive put over 200K on 1 truck. I only use them if it's below 0, and that's for antigelling, which again, I've never had a problem with up here in frozen Fargo....
only thing I keep hearing is to add in some cheap walmart two stroke oil in the tank
people run used motor oil, veggie oil, ATF in these
I add some 2 stroke oil to my diesel tractor when I fill it up
I also use 3 oz per five gallons on all my gas powered carbureted machines since the ethanol and water eats aluminum fast. the oil coats the parts and no more clogged jets
ran my 420 tractor that way for 10 years and no more carb issues with ethanol
I started using the "witches brew", 1:5 oz power service diesel Clean:2 stroke oil and 1:1 oz 2 stroke:gallon fuel
SO for a 20 gallon tank, 4 oz Diesel Clean and 20 oz 2 stroke oil.
There was a very noticeable difference in how my truck idled and ran. So noticeable, my buddy told me it was running smoother and asked what I had done. I am a belieber
UH.... Believer.
UH.... Believer.
UH.... Believer.
UH.... Believer.
https://opti-lube.com
Received 3,107 Likes
on
A very wise and knowledgeable sole advised me to at least run some kind of two stroke oil as an additive to help the injectors once I rebuilt them....
I do the same with Amsoil TC-W3 and power service or on occation I pony up for OptiLube.. Does it make any difference, yeah maybe.. I get a little piece of mind feeding her good once in a while..
Raceallday
06-29-2008 05:28 AM
