Fog lights, some opinions please.
Here's the setup I like:
Mounting directly to the top of the bumper makes it easy to mount them solidly. And I like to aim them pretty far to the sides which you can't do as well if they are recessed into the bumper or grill. This way the two beams just barely overlap in the middle, but they spread way out to both sides.
Also I like the '70s - '80s style of lights mounted to the bumper, but that's me.
It doesn't (much) matter which lights you use, the wiring won't mind. Aftermarket or factory you need to wire it either way.
Personally I like to be able to keep my fog lights from coming on, but I never want them on if I don't also have my running lights on. So I tapped into my running lamp circuit. From there I go through a switch (mounted under the dash) to a relay. So the fog lights won't be on unless the extra switch is on. But if the switch is on they will go on and off when I turn the running lights on and off.
If you didn't care for the extra shut-off switch you could just go from the running lights to the relay and the fog lights would go on and off with the main headlight switch.
Greyf100
08-14-2011 01:29 AM
kengarchow
1999 to 2016 Super Duty
04-01-2008 09:16 AM
