A whole new front suspension, excluding the steering, would be ball joints, radius arm bushings, and wheel bearings and/or hub assembly.
Pivot bushings, spindle bearings, sway bar bushings (if equipped). And then you can decide on whether or not you want to replace the three u-joints since you already have it apart.
I have yet to see a hub assembly include all the bearings, races and seals. Usually a hub assembly is just the hub and rotor.
