cruise control
Likely is. Test the master cylinder pressure switch with an Ohm meter , plug off just as soon as you can before it cools.
If open, that's your problem.
The fluid expands some with heat and can open the switch contacts, especially if an after market switch is used in place of a Ford part..
Good luck.
Good luck.
