Are my temps high?
Old 05-25-2016, 03:42 PM
cory5517's Avatar
cory5517
cory5517 is offline
Are my temps high?
I recently replaced my thermostat with one from Ford and my coolant temp gets up to 208 and oil temp gets up to 211. Are these temps normal for being unloaded?
Old 05-25-2016, 04:00 PM
Deep South's Avatar
Deep South
Deep South is offline
What is your ambient temp outside? Are you driving on flat roads? Is your oil system stock? Seems high if your just cruising on flat roads and it's not blazing outside.
Old 05-25-2016, 05:26 PM
cory5517's Avatar
cory5517
cory5517 is offline
85 plus degrees outside running 60 mph up and down some small hills
Old 05-25-2016, 05:33 PM
69cj's Avatar
69cj
69cj is offline
My OEM t-stat ran 204 consistently for 10 years. That's a very good area to run for efficiency.
Old 05-25-2016, 06:15 PM
cory5517's Avatar
cory5517
cory5517 is offline
Starting to think the Napa thermostat I installed years back wasn't allowing temps to warn up to efficient temps
Old 05-25-2016, 06:18 PM
WatsonR's Avatar
WatsonR
WatsonR is offline
Needs to be more than 185 to allow closed loop fueling. 200 is good for fuel efficiency, closer to 210 perfect.
Old 05-25-2016, 06:58 PM
jsm180's Avatar
jsm180
jsm180 is offline
I run 190-192 empty with ac on, 196-200 pulling the 5th wheel ac on. Been that way for 4 yrs and 2 oem stats.
Old 05-25-2016, 07:10 PM
Macrosill's Avatar
Macrosill
Macrosill is offline
I run 190 - 192 also with a Ford t-stat. I plan on trying the Mishimoto 200 stat one of these days. Probably when I install a coolant filter as I have to drain the coolant a bit anyway.
Old 05-25-2016, 07:26 PM
tfunk88's Avatar
tfunk88
tfunk88 is offline
Those temps seem pretty high for a stock stat with no load and average ambient temps. Should be in the low to mid 190's for ECT
Old 05-25-2016, 07:39 PM
Benchwrench's Avatar
Benchwrench
Benchwrench is offline
at any given time, Scangauge II claims 6-7 degrees cooler than analog Autometer.
Old 05-25-2016, 10:20 PM
mhoefer's Avatar
mhoefer
mhoefer is offline
When was the last time the radiator, intercooler have been cleaned, dirt and dust and dead bugs are going to reduce cooling capacity significantly, sounds like you are running slightly high but only marginal. If you are cleaning it, it has to be back flushed with low pressure water so the fins are not bent, and you need to be careful not to pry or poke any holes in the rad. It might be worthwhile to test a different thermostat. After that, I would be thinking water pump. What are your oil and water temps after an overnight cold soak,do they match?
Bigtruc
20
12-26-2013 10:24 AM
DesertStorm
07-20-2012 01:39 PM
Bob2626
12-31-2011 09:43 PM
mickpowell1967
04-06-2010 06:51 PM
TRX250R87
2004 - 2008 F150
12-21-2006 08:57 PM
Quick Reply: Are my temps high?
