Dashboard
Dashboard
You'd have to remove the trim from the black plastic panel, to be able to pull it from the dash. Take a thin blade screwdriver to pry the trim off, then you'll see the Allen wrench screws to remove.
you will also have to take the headlamp **** off, and use the thin blade screwdriver to pop it off. The fuel switch unsnaps from the wiring harness.
chevyassasin
05-28-2010 12:42 PM
86Stepside
05-12-2008 12:14 AM
