92 f250 351 trasmission OSS
First time posting, long time lurker lol. So i ended up buying a 92 f250 with a 351.. when i got it was high idling and etc.. so i worked the issue and solved TPS was bad.. took it for a test spin and felt like i it had no power and wasnt shifting.. sooo.. after crawling around i noticed a sensor not hooked up.. simple enough hook it up.. now comes the issue.. i have one plug that isnt hooked up and it doesnt fit the sensor.. went and bought the OSS connector and now im at a lost to the next step. thanks
heres the new connector
only unconnected plug
the wire loom stripped off..
Can you post more pictures of the transmission? Especially the pan. How many bolts are on the pan? Like it was mentioned, an F-250 should only have an E4OD or a C6, neither of which should have an output speed sensor. The earlier E4ODs had a speed sensor on the tailshaft housing with the speedometer cable, but what you have is not that.
Edit: It looks like someone put a 4R70W into your truck. The 4R70W was never put behind the 351, and the 4R70W wasn't even offered in the trucks until '94.
Unfortunately this leaves you with 3 options:
A: Remove the 4R70W and replace it with the E4OD that's supposed to be in there
B: Convert your entire truck's engine harness over to the 94-95 F-150 5.0 4R70W harness (You will need to convert your truck to mass-air to do this):
C: Keep the 4R70W and control it with an aftermarket transmission controller.
Good point. I was thinking of 4R100 to E4OD, and that will work, but you're right, there were no 4R100s that had a small block bolt pattern. This has to be a 4R70W. The computer in the truck won't know how to control a 4R70W even if you find a way to connect the OSS.
No, it is not. Ford never made this combination, so you would have to create your own computer. There isn't one in the world that will run a 5.8L/4R70W.
BrokeItAgain713
03-15-2016 04:30 AM
Macrobb
29
08-13-2014 01:16 PM
