Oil Pan
Old 05-24-2016, 11:32 AM
smithm31's Avatar
smithm31
smithm31 is offline
Oil Pan
The previous owner of my 97 F350 7.3 was somewhere out West several years ago and stopped at one of the quicky oil change places and had the oil changed. Along with the oil change they also overtightened the oil plug and stripped the threads in the oil pan. He installed one of those oversize plugs that cuts its own threads. This worked pretty good for awhile but has now started dripping pretty bad. I have tried tightening it a little, but it just keeps leaking. I believe I can get a larger plug and cut new threads to match it. I am worried if I do this how will I keep metal shavings out of the pan or how can I get them out if they get in oil pan. I thought maybe some type of magnet that I can move around through the hole? Any ideas. I don't think the oil pan need to be replaced. There should be some way to repair this. Thanks.
Old 05-24-2016, 11:38 AM
knottyrope's Avatar
knottyrope
knottyrope is online now
usually if they tighten you can change the washer on the plug. After cutting threads I just use mineral oil or solvent to flush it out after. the chips wont go far so a magnet will help get them out. You can also magnetize the tool so chips wont go any where. I use a strong hard drive magnet and wipe it down the bit several times to magnetize it
Old 05-24-2016, 04:23 PM
DZL JIM's Avatar
DZL JIM
DZL JIM is offline
PREMIUM SPONSOR
Maybe gob a bunch of grease on the bolt for when it's first cutting it's threads. Then remove it and clean it off, the shavings like to stick to grease.
__________________
'96 7.3 F-350 Reg Cab 4x4 - bought new.
'04 6.0 E-350 custom 4x4
'08 6.4 F-550 Reg Cab 6 spd 4x4
'17 6.7 F-250 KR ccsb 4x4
Old 05-24-2016, 06:13 PM
krifenbu's Avatar
krifenbu
krifenbu is offline
I would suggest buying a fumoto valve that fits in the new threads. It has a rubber gasket washer on it or you can swap it out for an o-ring. Then you won't have to take it out again and damage the threads any further.
Fumoto® USA | Quick and Easy Engine Oil Drain Valves
Kevin
Old 05-24-2016, 09:37 PM
fordpride's Avatar
fordpride
fordpride is offline
Problem solver I'd have a fab shop drill out the old threads and tig weld a new nut in. I just had this done on one of my work truck a couple months ago
Old 05-24-2016, 09:41 PM
fordpride's Avatar
fordpride
Old 05-25-2016, 09:42 AM
knottyrope's Avatar
knottyrope
Did you tig it while it was on the vehicle?
Old 05-25-2016, 10:54 AM
fordpride's Avatar
fordpride
Yes they did
Old 05-25-2016, 11:06 AM
knottyrope's Avatar
knottyrope
I am surprised the oil film left in the pan didn't affect the welding
Old 05-26-2016, 11:48 AM
RÖENTGEEP's Avatar
RÖENTGEEP
RÖENTGEEP is offline
FOREIGN GURU
Question
Could be use just an Heli Coil insert?
Old 05-26-2016, 12:05 PM
knottyrope's Avatar
knottyrope
heli coil could work but you have to still drill and tap it
If helicoil comes loose you may not be able to tighten the plug and be leaking
Old 05-26-2016, 12:52 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Arrow
Yes for sure; there are another kind of inserts like helis, I dont remember the name, but Glenn has used in one of the HPOP changes
Old 05-26-2016, 01:51 PM
fordpride's Avatar
fordpride
This is a option
Old 05-26-2016, 07:42 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Glenn54
10-18-2016 11:48 AM
drz400dp
6.7L Power Stroke Diesel
02-04-2016 05:09 AM
blueoval65
Modular V8 (4.6L, 5.4L)
10-15-2012 06:39 PM
acom01
08-09-2010 09:15 AM
ejolliffe
06-11-2007 06:26 PM
Quick Reply: Oil Pan
