2015 6.2L run without oil for 30sec-1 minute, maybe more.
#91
#92
#93
Thanks for the reply, FXDS1340.
I’ve looped in a customer service manager for your region. Your CSM will review your case, and will be in contact with you via phone.
Have a great day!
Tricia
Have a great day!
Tricia
#94
Thank you Tricia! Fortunately this may all be worked out in the end, as the GM is a very nice guy and eager to make this situation right. I still want to speak with the service manager for my region though. All the help and support in this tough situation is greatly appreciated.
#95
#97
Please confirm the name of your dealer. This is to make sure the correct customer service manager is assigned to your case.
Tricia
#98
Tricia, thanks again! The lady called me this morning and everything was confirmed with her. A solution is still in the works. Hopefully I'll have some news Tuesday afternoon. The truck is on a lift right now with the oil pan off.
#99
#100
I'd be more worried about the cam bearings. The older modular engines didn't use cam bearings, the journals rode directly on machined surfaces on the head. I've read that the first damage to occur is typically the head where the cam journals ride.
I'd say let them pull the pan and inspect for damage. If there's any damage they owe you an engine.
#101
We're not out of the clear yet, but it has been made apparent I'm getting my equity back, whether it's in the form of a check, or a new truck with my equity put into it and as much discounted as possible, and you know what that means. We'll see what happens Tuesday. I don't want a stupid warranty... useless paper and I don't want the truck anymore either.
My loaner truck is a 2016 F-150 XLT Texas Edition with the Eco-Boost 6. Man what a fun engine... that is the engine that should be in the F-250, not the 6.2. Almost feel like I'm in the wind on my old evo HD when I'm in the eco boost... that snappy break your neck throttle response.
#102
Sounds like they're going to make the situation right, and I'm glad to hear it. If it happened to mine I'd be happy with a new engine.
Yup, completely agree with that. I have a 6.2L F350 I drive at work, and the EB really puts it to shame. Of course it's moving a ton less weight, but it definitely has the low-end torque advantage. I'd love to see an EcoBoost HD in the next gen Super Duties!
Aaaah, but I digress....
#103
#104
Looked at the rod caps and the crank journals on my truck. Apparently they dont use babbitt anymore, but the rod caps and stuff are coated with chrome, or something. Very smooth. The caps look fine but the crank journals do show a little bit of damage. Doesnt really matter to me either way because I'm not leaving with the truck, but damage did occur. I just apparently caught it before it did a serious melt down.
#105
