Spring cruisin' - Ford Truck Enthusiasts Forums
Spring cruisin'
Old 05-23-2016, 01:11 PM
tip49's Avatar
tip49 tip49 is offline
tip49 is a name known to alltip49 is a name known to alltip49 is a name known to alltip49 is a name known to alltip49 is a name known to alltip49 is a name known to all
Spring cruisin'
Had a nice day Friday, so cruised in the '50 truck.
About the third time I've been out with it since winter. Truck purred along, it likes slightly cooler weather.
Got up Saturday to rain, as I walked past truck I noticed the sound of the electric fuel pump being on. Quickly disconnected battery cable and checked ignition key, but it was off. Pump is wired through ignition on, then through roll over switch.
Fault must be in ignition switch (original) or shorted to another hot all times wire.
Did not get a chance to trouble shoot , as it snowed all day Sunday ! I worked on the '59 Beetle all weekend and got it running this morning. Have a rattle" in the re-built motor, that I thought I cured by removing engine and replacing clutch pressure plate, Nope.
I love this hobby !
Tom
Old 05-23-2016, 02:02 PM
ALBUQ F-1's Avatar
ALBUQ F-1 ALBUQ F-1 is online now
postin' fool
ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.
I hope the fuel pump didn't pump your engine full of fuel!
Old 06-05-2016, 12:45 AM
tip49's Avatar
Trouble shooting
Started looking for the issue with my fuel pump today, pulled relays, replace EEC and will buy new relays Monday, Took time to rewire the cab under dash. Measured contacts on both fuel pump relay and EEC relay. Both seem defective , as they have continuity across control contacts in de-energized state. hope replacing them solves problem, as weather is right for cruising.
Tom
Old 06-05-2016, 07:22 AM
ben73058's Avatar
ben73058 ben73058 is offline
ben73058 has a great reputation on FTE.ben73058 has a great reputation on FTE.ben73058 has a great reputation on FTE.ben73058 has a great reputation on FTE.ben73058 has a great reputation on FTE.
Hey Tom,
Hmmm... You know the thing that concerned me the most - It's still snowing
at the end of May! That's crazy & horrible all at the same time. You'll fix that
electric fuel problem - not sure what you can do about it snowing in the summer.
I hear South Florida is nice this time of year....
Hang in there & keep us posted on the electric problem & the snow...
Ben in Austin
1950 F1 (351W/AOD)
Old 06-05-2016, 11:24 AM
ALBUQ F-1's Avatar
postin' fool
That's mighty suspicious that both relays went south at the same time?! Is it possible the contacts fused together because of too much current? Does your FP draw a lot more than stock Ford? Might be worth opening the relays to see how they failed.
Old 06-05-2016, 08:23 PM
tip49's Avatar
current draw on fuel pump
Ross, not sure what the current draw is on the fuel pump. but fusing held. I read that the EEC might be the problem, if EEC relay picks up before ignition is on so I used my spare. I haven't checked the relay circuit power with key off. May go out and verify now. I think the fuel pump relay gets power from EEC relay when ignition is on.
Stay tuned
Old 06-05-2016, 08:54 PM
bobbytnm's Avatar
bobbytnm bobbytnm is offline
Roast em' if you got 'em
bobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud of
Sorry to hear of your fuel pump woes.
How does the EEC control the fuel pump? Does it energize the circuit or ground the circuit. My guess would be that the computer controls the ground side......but, I've been wrong before (just ask my wife....LOL)
Good luck with it
Bobby
Old 06-18-2016, 08:32 PM
tip49's Avatar
One problem solved
Had time to look into fuel pump relay gremlin yesterday; metered out circuit for EEC relay and Fuel pump relay.
Bobby, fuel pump relay gets power when EEC relay picks up; from ignition switch ON. The reading I did said the EEC relay gets ground from EEC but wiring diagram and tracing show the ground goes directly back to the battery.
So with battery disconnected, I started looking for ground issue in the EEC relay first, it would stay on after ignition turned off ?? I started fooling around with wires under dash, and inadvertently moved the signal assembly, relay turned off ! Pulled assembly apart and tried to clear the wiring to the light, it seems to be a hot wire being grounded in the assembly. That didn't work so disconnecedt light circuit for now, but still have signals.
Plugged fuel relay in with switch off and fuel pump started up ?? So tested relay and it seemed good, but noticed after some time, that the wiring harness was supplying hot to the out going wire to the pump?? Changed wire lead to appropriate spot on relay and voila. I replace the fuel pump relay, but there must be different configurations for different years.
Cruised for rest of the day ! Sorry for long post
Old 06-19-2016, 07:28 PM
bobbytnm's Avatar
Excellent!
I'm glad you were able to work it out
Happy motoring
Bobby
Old 06-20-2016, 10:15 PM
tip49's Avatar
Wipers and speedo
Opted to ptu the electric wipers back in this weekend; couldn't get the vacuum pump working properly, so made some adjustments to the mounting bracket and put in the electric motor. Works for now, until the first rain storm, probably.
Also put the instrument cluster back in yet again, and now have speedometer working ! It reads about 5-10 mph too high but I can calibrate with the electronic sender.
Made a few miles in the truck, the last couple evenings; weather is perfect for it.
Changed oil and may have fixed slow leak in transmission plug, fingers crossed.
Tom
Old 06-21-2016, 12:23 PM
ALBUQ F-1's Avatar
postin' fool
Quote:
Tom
Exactly what happened to me on the drive back from Truckstock '13! The other wiper fell off too and was run over by a semi......
Old 06-21-2016, 10:19 PM
Cougar54 Cougar54 is offline
Cougar54 has a good reputation on FTE.Cougar54 has a good reputation on FTE.
Quote:
Ross, I'm sure that wasn't funny then but made me laugh when I read it. And I thought these type of things only happened to me . . .
86 e350 motorhome no power to ignition Bobriant 1968-2013 Full Size Vans 3 05-04-2016 06:31 PM
1986 fuel pump relay woes....bought this truck to save from boneyard, please help fishingape 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 11 02-11-2015 01:46 PM
97 F350 gas, fuel problem weekender7 Fuel Injection, Carburetion & Fuel System 4 10-03-2014 08:44 PM
Ignition troubles cyris426 1973 - 1979 F-100 & Larger F-Series Trucks 9 11-22-2012 09:10 AM
Hooking up fuel shutoff solenoid flainn Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 13 09-23-2012 03:43 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
