Trailer Is Reluctant To Disconnect
#31
Received 6,680 Likes
on
#33
on
#34
I've got that same style coupler on my camper and car trailer. IMO, it is a very forgiving design.
Odd
The only thing I can think of is that the latch part of the coupler must be hitting the back of the ball at the same time the front of the coupler is touching the front of the ball. The angle of the head is probably what is making that happen.
One thing I've found with that design is that you have to get the latch pulled back far enough to the the pin back in latch in the open position. The way that latch swivels down onto the ball when the lock slides forward makes it possible for the locking mechanism to be in the way even with the latch slid back into the open position.
Now that I think about it, I seem to remember problems like this until I learned to pin the lock open. The latch goes back a lot farther than you would think to get the locking mechanism fully out of the way. The only way I've found to know it is fully open is by putting the pin back in the latch.
Try pinning it open and see if that helps.
If not, driving the rear of the truck up on blocks might help too. That would reduce the angle of attack the ball mount has relative to the coupler.
Odd
#35
on
When looking down at the hitch I was able to see the ground through where the latch slides. Maybe seeing the ground isn't enough clearance and I'll try sliding the latch back further. The ball seems to get stuck at the front of the coupler. I did get the ball to go back in the coupler when driving the truck in reverse, but it still wouldn't come out.
#36
#37
on
#38
#39
on
#40
#41
on
The picture in post #31 shows it hooked up except for the torsion bars. The picture below is with everything connected. It leveled out the front end nicely.
The ball mount does have a slight lean towards trailer. I added that. It didn't seem to have much tension. 3 links in the chain brings the bar to about 3/4 inch below the trailer frame. One more link and it is right at the frame.
New questions: can I add sway control to my existing setup? Do I need to?
#42
#43
Looking at the socket of the coupler that fits over the ball, it appears to me that the inward curve of the leading side is a bit excessive. This is going to cause the socket to capture the ball and not allow it to easily fall out. To me, this is a good thing when traveling down the road, and an inconvenient thing when trying to unhitch.
I'd say that copious amounts of lubricant is your best solution. Otherwise, the next time you go to hook up, lower the coupler down until the smallest diameter of the coupler is at the widest dimension of the ball, then take a look up underneath to see how much clearance you actually have around the perimeter of the ball. As mentioned, I'd bet the latch is adjusted just a bit tighter than it needs to be, decreasing the size of the "sweet spot" that allows the coupler to raise up clear of the ball.
#44
on
So far, the axle grease seems to have helped.
#45
Use grease. I have used both of these with success:
https://www.amazon.com/Reese-Towpowe.../dp/B0008F67JU
https://www.amazon.com/dp/B004X70LZA...EJYDWSE1ESN3BC
Even then sometime I have to jack up the trailer tongue, then jump on the truck hitch to disconnect. It all depends if the trailer has rolled forward or back a 1/2" or more.
351Cleveland C4
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
10-10-2014 08:20 PM
impwrdbym
07-05-2008 10:12 PM
