79 FSB leaning towards the driver side.
I recently noticed the Bronco has a bit of slouch towards the driver side. It has a 6" Superlift suspension lift, it's an all spring lift no blocks in the back. It also has the Superlift adjustable track bar. The lift kit has been on the truck for probably 5 years now. I don't baby this thing, especially up in the dunes it's been known to take flight from time to time. I checked the front coil buckets, the lower coil cups, and all the other brackets. Everything seems to be as it should up front. The rear doesn't appear to have anything out of place either, bent or broken brackets or leaf springs. I do have two things I have in question, one being front coil springs are noticeably bowed outward, maybe one is sagging more than the other. A while back I caved in and bent the lower coil cups, since then I straightened and reinforced them. The second thought I have, is it possible that the track bar adjusted too short possibly cause this? Any thoughts or ideas on this issue? Thanks again fellas!
Received 3,090 Likes
on
Pretty sure the body mounts are good. I had the body off the frame a couple years ago. All the rubber mounts have been replaced with polyurethane. The mounting locations on the body and frame have been reinforced with 1/8" plate. I don't have any broken leafs in the back, sounds like I'm gonna be buying a new set of coils. Is it possible for an improper track bar adjustment to do this?
on
The track bar shouldn't cause it to lean. But it shouldn't be too hard too see if it's adjusted right. The front springs should pretty much be mirror images of each other. They should both be pretty close to straight up-and-down when you look from the front, but if one is leaning in (or out) a little at the top the other should be doing the same thing.
Coil bow is common. I've seen it bad enough that on full flex the tire actually rubs on the coil spring. The angle on the lower mount can cause this, you need to make sure they sit nice on the radius arms. The top of the arms are not flat, so if you renforced your bottom plates with flat, and bolted them on, they can still lean and cause bow. You can mount the bottom plate so it is higher on the outside edge so the spring is forced to sit straiter. It won't hurt it at all. I had some issues like that when I had superflex coil springs with my one tons.
351ballsofford
01-28-2005 11:21 AM
