Light bar, tire bar, whiskey bar...electrical termination help
So you guys running the lights, i want to hook into power only when lights are on. Any thoughts on the best place to tie in for power. Have the harness made, relay ask that jazz, justy want to terminate power first then route
a auxiliary light wiring harness power wire should go directly to the battery. you can run your on/off switch for the relay trigger through any of the key on power wires in the fuse block such as the radio fuse.
your best bet for key on power is under or in the dash, everything under the hood is in a loom and or part of the ECU. that is why ford but those extra wires through the firewall. so you don't go digging into the computer harness.
If you really want some overkill rather than use a relay use a continuous duty solenoid. It looks like a Ford starter solenoid, the four lugs hook up just like a relay, and you can use some seriously large wire with it. Sturdy? It is used as a glow plug relay on a Dodge diesel and as a switch on a 36 volt golf cart.
Do I use it, oh yeah.
why ?
his light bar draws maybe 15 amps. a typical Bosch style relay is rated for 30 or 40 amps continuous duty and cost about $10. a typical starter solenoid is 100+ amps and good ones start around $50
it's your money spend it as you wish but there is nothing to be gained by using a 100 amp relay when a 30 amp is already twice what is needed.
Okay I'm asking, if in the power distribution box, the unused power locations, had anyone used the terminals in here. That kind if thing
when they say "unused" the fuse cavity is vacant, meaning no terminals or wire. you would need to run wire and terminals to that slot if you are wanting to integrate your loom into the block for a factory look.
