94 F150 - Ford Truck Enthusiasts Forums
94 F150
Old 01-18-2002, 02:40 PM
Lightning2 Lightning2 is offline
Lightning2 is starting off with a positive reputation.
94 F150
I have a 94 F150 that came with a 4.9 & I had it converted over to a 5.0,my problem is it has a rough idell at cold startup, tail pipes are burning black as coal,& only gets 13.5 miles to the gallon. I had it put on a computer & everything showed up ok.
Thanks for any advice.
C.M.
Old 01-19-2002, 04:51 AM
94 F150
Old 01-21-2002, 10:59 PM
madman666's Avatar
madman666 madman666 is offline
madman666 is starting off with a positive reputation.
94 F150
Check for any vacuum leaks; also make sure the IAC connector is plugged in, and also the ECT. Better off, check to make sure all sensors are plugged in.
Did you do the conversion, or did you have it done?
If you had it done, did they do every thing right?
13.5 MPG isnít bad for gas mileage; I get around 11 MPG or so
Old 01-23-2002, 02:33 AM
94 F150
I had the conversion done,the place that did it has been there for 20 years plus. I read some other topics on here and did what they recomended.(it helped) I haven't ran a full tank of gas thru it yet to check the MPG,but before at a 100 miles it would be on the low side of a half a tank,at a 110 miles it is on the upper side.
Where are the vin numbers at on the 302? They said it was a 302 H.O. but the plugs that were in it did not match the H.O.
Sorry so long winded.
Thanks for the info.
Carl
Old 01-23-2002, 04:11 PM
zr1jeff zr1jeff is offline
zr1jeff is starting off with a positive reputation.
94 F150
I have had the same problem twice in the 8 years I have owned my 88 with a 351. The computer kept sending me on a wild goose chase as far a codes go. Turns out the fuel pressure regulator gave up the ghost and was sqirting full fuel pressure to the injectors at all times. Tail pipe ran black and milage dropped to about 6-7 mpg range. Replace the triangular regulator and wham-back to normal...Hope this helps.
Old 01-24-2002, 01:43 AM
Ryan50hrl's Avatar
Ryan50hrl Ryan50hrl is offline
Ryan50hrl is a splendid one to beholdRyan50hrl is a splendid one to beholdRyan50hrl is a splendid one to beholdRyan50hrl is a splendid one to beholdRyan50hrl is a splendid one to beholdRyan50hrl is a splendid one to behold
94 F150
As for your gas milage,,,feel lucky that your getting 13. I get 9-10 with my 95 F-150. Granted it does have 35's on it. But it only got 12 stock.
Ryan
Old 01-24-2002, 05:25 AM
TexasGuy001 TexasGuy001 is offline
TexasGuy001 has a very good reputation on FTE.TexasGuy001 has a very good reputation on FTE.TexasGuy001 has a very good reputation on FTE.TexasGuy001 has a very good reputation on FTE.
94 F150
Where is MAP sensor located on 94 F150 5.0? countryboywatts 1987 - 1996 F150 & Larger F-Series Trucks 10 01-02-2016 06:35 PM
94 to 2011 motor swap 94superlightning 1987 - 1996 F150 & Larger F-Series Trucks 11 01-06-2013 10:31 PM
94 f-150 5.0 aode to c-6 shane1 Clutch, Transmission, Differential, Axle & Transfer Case 1 01-31-2005 03:43 PM
94 f-150 5 speed tranny, how much is it worth? whoozeyourdaddy Clutch, Transmission, Differential, Axle & Transfer Case 3 12-31-2004 07:02 PM
94 f150 deerhunter06 1987 - 1996 F150 & Larger F-Series Trucks 3 10-23-2004 12:18 AM
Tags
49, 94, 94f1580, codes, computer, f150, ford, forum, fourm, gas, iac, location, mileage, raptor, turbocharger
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
