Complete a/c system rebuild on my E350
I replaced the rear expansion valve today, when I checked the blend door it cracked. I took it out and reinforced it with scrapes of abs plastic and abs cement as there very expensive to replace.. I installed the new condenser end vacuumed the system for 45 mins. Charged it with Dupont Suva and I'm getting a good 35 degree differential now. When checking the blend door I found the vacuum actuator worked well. If it malfunctions again it must be in the control valve behind the dash.
CountryBoy685
05-03-2003 07:22 PM
