Anyone else get an occasional "squawk" noise?
I have a 2016 F250 extended cab with 8 foot bed with snow plow and camper package currently less than 2500 miles on it. Every once in a while when I make a turn (typically a left hand turn) I will here a brief noise that sounds like a rubbing or "squawk" noise. The noise doesn't seem to be related to the turn so much as to the roll of the truck when it unloads / loads the suspension. I'm guessing it might be related to sway bar bushings or something similar, but I just don't know.
I have tried to find a stretch of road near the dealer where I can make the noise happen so I can take a tech for a ride so I can let them hear exactly what I hear, but as hard as I try I cannot reproduce the noise consistently.
I have visually checked underneath and I do not see anything wrong and I suspect it's not serious, but I'd like to know the cause and obviously correct the problem.
I would like to know if anyone else has experienced this or if someone could provide some insight as to what the cause may be.
Thanks in advance.
Thanks in advance.
Subscribing...I here something as well on left turns when theres a dip in the two road surfaces and the suspension articulates. It sounds more like the ABS doing something on the front left wheel. Others have mentioned this. The best way to "split the dictionary", isolate this, is to disconnect the ABS and try to reproduce it.
Mines a 11, 6.2 with 60K.
I never thought to consider the ABS. Thanks.
Have a new 2016 SD with 6.2L, mine has 20 inch wheels on it. Anyway have 3500 miles to date and the other evening slowing down and making a left hand turn, to turn into our addition. For a brief second I heard what sounded like the tire touching the wheel well but I couldn't see anything after getting home after looking real close. I believe now it was something with ABS or the Advance Trac Electronic Stability Control.
Slightly larger tires. 285/17s, OEM is 275/17s Stepping up to 20s, new take offs soon as these factory rims have so much run-out the tires wont balance! Nice hugh! I dont see any tire contact. Ive had a wrench in my hands for 35 years. It sounds like ABS chatter to me. Not 100% sure as I dont have my foot on the brake pedal to feel it when it happens. I wont rule out chassis bushings or BJs at this point either. But at 60K I would hope not.
My '01 with 285's, when the suspension in the front is compressed and the wheels turned all the way, I get some rubbing. But that's a leaf-spring front-end, not the newer coil springs. However, the newer front-ends actually turn further because there are no leaf springs
Anyway, check the wheel bearings - if they are loose, you could be pushing them far enough that the ABS tone wheel moves far enough away from the sensor that the ABS system thinks the wheel stopped spinning.
If you want to check the ABS sensors, with the wheel jacked up, disconnect the ABS sensor connector for that wheel, and connect a digital volt meter to the sensor set to AC volts. Spin the wheel as fast as you can by hand. You should see .2-.3 volts from the sensor. If it's less than that, remove the sensor, clean the surface under it if it's rusty, which causes the sensor to pull away from the tone wheel.
Thanks for the tip. So what produces the voltage with the harness disconnected? The magnetics from the mag pick-up reading peaks n valleys on the tone ring? Pardon the ignorance have not had to operate on this system on either of my 250s...yet...well versed in all things automotive though.
Once upon a time, my brother-in-law had a problem with his Suburban. He would hit the brakes, and sometimes the ABS would activate making it almost impossible to stop unless you almost stood on the brakes.
Did the test I detailed, and turns out the sensor had been pushed away from the tone-ring by the rust under the sensor. Cleaned it up, problem went away. There was a Chevy equivalent of a TSB for it.
After that experience, I always check how rusty the spot looks whenever I have my wheels off - Ford uses the same Kelsey-Hayes system that Chevy did at the time. Not sure what they are using now, but the sensors are all the same principle.
One never knows if a sensor is going bad, so it's worth checking.
Thanks in advance.
Thanks in advance.
I have the identical occurrence that I noticed within a few miles of driving my (then) new 2015 Platinum CCSB off the lot, although I would describe it more as a scraping noise. It seemed to be generated anytime body roll exceeded a certain amount. I took it back to the dealer and they say they can't duplicate the problem.
I duplicated the identical noise recently using the hill descent control, and according to the manual "noise from the ABS pump may be observed...and this is a normal characteristic and should be no reason for concern."
I am copying this thread and taking it in to my service department when I visit in a hundred miles for my next oil and filter change. If this condition is as prevalent as it seems to be given the response to this thread, the service department should be aware of it.
