BBF and IFS in a 54
The BBF weighs approximately 150 lbs more than the flathead so there is considerably more load on the front suspension. I had a 460 in my 56 with a straight axle suspension and it was constantly bottoming out. Could I have beefed up the suspension to handle the added load...yes, but it would have made the stance of the truck too high and/or ride too stiff. I switched to a Corvette C4 IFS but that too came with it's own set of problems. Best thing to do is to take lots of measurements and have a firm design established ahead of time.
I have a 56 F100 over here in Blighty.
It's fitted with a Ford 460/C6, Mustang 2, tubular arms etc, Ididit column,custom steering shaft custom trans cover,trans mount. It's cosy, but it all does fit well.
I plan to rebuid at least bushings ,pins if springs are not good when I take them out I plan to replace with bb springs. I will see what happens when I mock up,see how much ride height with engine. Should a e been done but I started on the cab first. Lots of rust. Just started to hear that it might be too heavy for original suspension, I have the 223 and 272 both need to be rebuilt but both have syn4 speeds .we will see when I get there.
fastanfurious
09-20-2016 07:16 PM
bykpainter
17
11-18-2015 09:18 PM
Greywolf
General Automotive Discussion
24
03-22-2006 06:49 PM
