Why owning a diesel stresses me out.
#31
I think you're stressing yourself out.
Mechanical failure can happen in any piece of rotating machinery.
I've seen brand new motocross bikes grenade on their first day of usage. Does that mean it happens across the board? No. On the other hand I know a dozen 6.4 owners that have had a moderately good experience with that engine. Take care of it and it will take care of you.
#32
#33
We'll file this under "random uninformed crap people say with confidence and authority when really they're just whistling out their **** sphincter."
#35
To the OP: Everything breaks, some more than others. Even back when the 7.3 was available new, I wouldn't touch a diesel with a ten-foot-pole because of all the things I've seen with diesels. Not Ford's, mind you, other medium and heavy-duty diesels.
I was once driving a box truck for a job... 4-cyl Isuzu diesel. Driving on the highway at 60 MPH. It ingested what was probably a single drop of water and grenaded all the pistons, cracked two of the cylinders and spun a rod bearing.
Cost was astronomical to rebuild at the time - I got a break from my machinst for the company I worked for, and it was still over $5K - that was 27 years ago.
That experience, and all the others I saw go through my machinist's shop (I used to visit every day for lunch) caused me to never ever buy a diesel.
If I have a load big enough to require a diesel, I'll rent one
#36
Originally Posted by Krewat
File these two in there as well:
#37
Diesels used to be relatively simple...I like to think they will again some day. Today's diesels are trying to make the EPA happy as well as meet customer expectations for power. Engine designers are scrambling to make everyone happy.
Years ago water got into my dad's diesel storage tank. Without knowing it he pumped his 1966 tractor half full of water. Tractor barely made it a few hundred feet before it quit running...go figure. I drained the water out of the fuel filter and tank onto the ground and closed the valves when diesel started to come out. I pulled the injectors and cranked the engine until diesel flowed. Took about 30 minutes total but had it running again... didn't even change the filter until later when I had time. That original pump and injector set ran 15 more years before being replaced.
#38
#39
Yeah it's like an old single barrel carbureted engine with no emissions. Super simple to work on, but very inefficient, inconsistent, and dirty. Trying to compare an old tractor to a modern light truck diesel engine (PS, Duramax, etc) with HPFP and so on is apples and iPhones.
#40
Older diesels were dirty as in pollution, but not inefficient or inconsistent. That old tractor still gets the job done reliably...it's just more polluting. Early Powerstrokes, Duramax (pre-2007) were in what I call a "happy place". They had enough power, good fuel economy, and were fairly robust. It's meeting the new EPA standards that has greatly complicated today's diesels and really given them fits. Gas engines went through similar type growing pains when tougher emissions standard first came out.
That being said, even the above motors are still pretty sensitive with the fuel system abd injectors arent cheap
#41
True that. Before I fill up my 2002 diesel, I run a fuel sample into a half gallon glass jug to look for water or dirt. I've only left one station for contamination but that was cheap peace of mind.
