Removing stubborn valve covers on Ford 302?
Old 05-21-2016, 05:17 PM
Maravich12's Avatar
Maravich12
Maravich12 is offline
Trailering
Hey guys,
Oil has been leaking from the valve covers on my 72 302, so I was wanting to remove them, prime/paint and replace the gaskets. I removed the 6 bolts on each side, yet they won't budge. Am I missing something? Used a rubber mallet, but these things are stuck on tight!
Old 05-21-2016, 08:11 PM
HIO Silver's Avatar
HIO Silver
HIO Silver is offline
Someone prolly used RTV to glue'em on. Pry 'em off.
Old 05-22-2016, 01:06 AM
Maravich12's Avatar
Maravich12
Trailering
Would that warp the covers at all? These are OEM, so I didn't wanna damage them or the mating surface too bad.
Guess I could try putting a putty knife or spacer underneath there and trying to pry. Tough to get under there since there is no give at all.
Old 05-22-2016, 01:18 AM
GaryKip's Avatar
GaryKip
GaryKip is offline
Just go at it a little at a time, from any angle that you can get at.
Old 05-22-2016, 10:25 AM
jbbott's Avatar
jbbott
jbbott is offline
I used a thin paint scraper for drywall patching. Go very slowly and just try to work your way around the entire cover. Then pick a corner and gently pry up.
Old 05-22-2016, 07:38 PM
CougarJohn's Avatar
CougarJohn
CougarJohn is offline
Beat harder with the rubber mallet or get a bigger one. They will pop.
At worst, you buy two more tin covers. Cheap and plentiful.
Old 05-22-2016, 08:39 PM
orich's Avatar
orich
orich is offline
2x with John if someone applied RTV to both sides of the gasket you will be for a fight freeing them up..
Orich
Old 05-22-2016, 09:12 PM
CougarJohn's Avatar
CougarJohn
If nothing works, put the rubber mallet to the cover, get a heavy maul and rap the rubber. The gasket will split. These things can be ornery. They need talking to with profanity.
fordka
Ford Truck Parts for Sale
08-03-2013 09:31 PM
David LaPell
10-03-2010 12:27 PM
GotFord83
05-30-2010 01:38 AM
bonesbmx
WTB - Parts & other
12-18-2009 06:02 PM
71FoMoCo
06-05-2003 05:34 PM
Quick Reply: Removing stubborn valve covers on Ford 302?
