C6 Stator support bushings??
Does anyone know of a part number for stator support bushings that are .140 outside diameter? I took the pump out of a 1971- PGA-AG to rebuild it and when I put the bushing in it just fell into the shaft. So I knocked the bushing out of a 1974 C6 pump and they were the correct size for it. Were there two different size bushings? I am reasonably certain that the pump was original to that trans.
I thought I would pass on what I found out since I posted this. I talked to a local trans parts distributer. There is only one bushing size for a C6 stator. He called a guy who has been in the transmission business for 40 years, "he had never encountered that". The consensus was that Ford had these oversize bushings on hand to salvage bad castings and machining mistakes. Something that was not uncommon in the 60's and 70's.
rpatrick
07-11-2011 06:46 PM
dezmoduo
07-16-2002 11:14 PM
