You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
I was curious as to what the HP rating was for a '92 F-150, 4x4, auto, 302, Nite Edition? It's my friends truck and he bought it from the dealer with 73,000mi on it. It seems to have a lot of power and we think it's been modified, but there isn't any performance parts on it that we can see. Another friend of ours has a '90 fullsize Bronco 302, 5 speed, 4x4, and it doesn't have anywhere near the power that the Nite does. I test drove a '94 Flareside 302 5 speed 4x4 today, and it seems to be as gutless as my friends Bronco.
Any input is appreciated.
Did you check to se it has a computer chip?
No duel exhaust?
Does it have the mass air conversion?
It could just be that he got a good one, and also the low miles don’t hurt.
>195HP
>270FTLBS of torque
>No duel exhaust?
>miles don’t hurt.
I'm assuming the performance computer chip plugs into the PCM, so where we find the computer on his truck? (I'm not too familiar with newer computer controlled Fords, just old ones)
We put true duals on it last summer, but even with full exhaust it still hauled #####.
What's a mass air conversion? (I feel like should know this one already)
The computer is located behind the drivers side kick panel, you gotta remove the panel then you can get at it, if a someone did put a chip in the computer, they should have put a sticker on the computer saying there is a chip in it.
You have to remove a little plastic cover on the computer, and in side is were the chip would be, if there is no chip then it doesn’t have one, also there should be some grease on the terminal if there is not then someone once installed a chip.
Mass air conversion is a conversion to mass air hmmmmm.....
Since his truck is a 92-model year he does not have mass air, 94 was about the first year they put them in trucks. His truck has something called speed density, where it uses a map sensor to sense the air coming in to the engine.
When you do upgrades to the SD it doesn’t adjust to the upgrades, and can cause bad gas mileage or make it feel sluggish.
The reason you convert to mass air is if you do some upgrades like, cam, heads or port and polish, K&N air filter.
Mass air can sense the air coming in to the engine and adjusts the fuel to the air, and therefore makes your engine run better.
The sensor is right after air box and before the Throttle body it has wires going to it and its about 2 1/2 inches wide, you’ll see it if its there.
The person who owned the truck before your friend may have put a more aggressive cam or ported the heads, there is almost no way of telling though.
Anything else?
[updated:LAST EDITED ON 16-Jan-02 AT 06:39 PM (EST)]Thanks for the info. That should be all the info we need to see if it has been modified. BTW I like your e-mail address.
I have a '91 NIte with the 5.8 in it, and let me tell you, it hauls *****. Compared to my uncle's truck (same year, engine, just not Nite) mine seems to have a larger exhust pipe, like something a "Sport" model would have. Since I got it I added a K&N FIPK and it is even quicker now.
__________________
Black 2000 F150 XLT S/C 4X4-5.4L, Flowmaster, K&N, Billet Grille, Snugtop. RIP '91 Nite "That Ol' Fords Sure Fast on the Draw / Out Gun the Chevys, Out Run the Law" - Brooks and Dunn
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
