Starter ring gear question -another one
I am approaching the assembly stage with my engine and have discovered that the flywheel gear needs to be replaced. I have another flywheel that has the same issue. I counted 112 teeth on my flywheel, and Mac's has a ring gear with the same tooth count and the diameters appear to be the same, but the description only mention the V8. Do you guys think this is the same as mounted behind the 226 6 cylinder with a 4sp crashbox?
Howard, if the gear count on the starter and flywheel gear match, the starters are interchangeable. The starter that came from your spare engine has been running on another member's V8 powered F5 for some time, now. Tooth count and diameter the same, you should be good. Perhaps someone who knows for sure will weigh in.
Seems like this has been discussed before, and there is a difference. Also some discussion of "correct" tooth count on flat-6 starter drives.
Here's all I could find, it has a source for the ring gears on the second page. But they are described as 114-tooth?
https://www.ford-trucks.com/forums/1...ew-member.html
The 114 tooth gears for the 226 are near impossible to find. Best way to find one is off a donor engine. They require the 9 tooth starter gear. The next best thing would be the 112 tooth gear, it came on the 226 with an 11" clutch. It uses the 10 tooth starter drive. I have seen the 112 gear more and I have two NOS.
Not the same.
Not the same.
1948/49 226 L-6.
8BA-6384-A .. Flywheel Ring Gear - 112 teeth / Obsolete
1948/53 239 V8.
Pic: 6384 ring gear applications:
