ring gear damage?
You have to pull the flywheel, so pulling the trans is easiest. The typical way of removing the old gear is to split it between teeth with a chisel, sometimes after drilling a hole in it. To install a new one, freeze the flywheel and put the new ring in the oven, then quickly slide onto the flywheel.
I started with grinding sounds so I pulled the starter and replaced the starter drive. Then it was jamming so I installed the bracket. Kept jamming. Decided to ditch the old starter and switch to a mini starter. I'm afraid if I install it I will get a few months of service and then it will eat up the new starter's gear.
Is your engine a 226? If so, count the teeth on the ring gear, it's either 112 or 114. Both were an option and if your start drive is wrong it could bind or do damage. Don't think just because you used the drive already in the truck that it's right, because mine was not.
Do you have a light-duty 3-sp? They aren't that hard to pull at all. I have had mine out at least 5 times for various reasons, LOL. Takes less than an hour after you've done it once. Perfect time to do the clutch, and have the flywheel faced if it needs it. An option is to buy a whole new flywheel with new gear already on it. They aren't that expensive.
In the shop manual for my '37 Buick it suggests flipping the worn ring gear to get more life from the other half. It's directions were simple, heat the ring until it changed color, but not red hot, tap the ring gear off, flip and reheat and drop back on using a hammer to tap into place. It was fairly easy.
As for pulling the tranny. I had to pull the tranny out of my panel truck. I pulled the seats, panels have two bucket seats, remove the tranny cover and I was able to left it out by hand once I got all of the bolts out and a floor jack under it to offer support. The three speed tranny isn't too heavy. I did it myself but it would be helpful to have help. I've also done it to other vehicles from the bottom but they didn't have the big access panel in the floor like our old trucks.
Just a few more suggestions to think about.
Obscurity, what size clutch do you have? Which trans?
