DPFE location on 93 f150 351W
For a 1993 F-150 with a 5.8L, look for the DPFE on the passengers seat, sitting there in its box with no place to go
Your truck doesn't have a DPFE, it has a simple EGR position sensor, its mounted onto the end of the EGR valve. It has one connector on it.
I see some parts places have screwed up their look-up tables, and have put a OBD-II systems DFPE as being on older year vehicles with EEC-IV!
A DFPE is a pressure sensor that has two hose inputs, the hose inputs come from each side of a special tube in series with the EGR flow. The tube has an orifice, a restriction in it, so flow rate equals a pressure drop across the orifice. The DPFE measures the pressure drop, which the EEC-V OBD-II compatible processor converts to EGR flow rate data.
In contrast, a EGR position sensor just has a pin that presses into the EGR valve, and reports back to EEC-IV how far open/closed the EGR valve is at that moment.
pickncrew
03-15-2008 07:26 AM
Mountaineer Boy
07-12-2005 04:12 PM
