Odd issue
Old 05-19-2016, 08:32 PM
MoBill122's Avatar
MoBill122
MoBill122 is offline
Papa Smurf
Any leaks around your oil cooler tube ?
Old 05-19-2016, 09:36 PM
dylansf23's Avatar
dylansf23
dylansf23 is offline
None. It's still dry and rusty lol.
Old 05-19-2016, 10:23 PM
z31freakify's Avatar
z31freakify
z31freakify is online now
Received 1,188 Likes on 816 Posts
Looks like you need injector O rings in your list.
Old 05-20-2016, 05:23 AM
dylansf23's Avatar
dylansf23
How can I figure out which one? Or with 326k is it worth it to just do all of them?
Old 05-20-2016, 08:30 AM
knottyrope's Avatar
knottyrope
knottyrope is offline
do one injector, drain fuel system, purge with clean fuel and fill with clean fuel
run for an hour or two and check filter
do next injector until filter is no longer black
or do all 8 if the above seems like more work
Old 05-20-2016, 08:36 AM
dylansf23's Avatar
dylansf23
I'm going to just do all. It's a twenty year old truck. I can check the injectors shape and see how everything else works too. Gonna see if I can borrow my buds computer and rest the hpop after its all back together. I need injectors. Per the wear and use(mileage) but right now they are all fine. (We shall see)
Old 05-20-2016, 10:16 AM
z31freakify
Do all of them with that many miles they need to be changed.
Old 05-21-2016, 12:17 AM
mcali2's Avatar
mcali2
mcali2 is offline
Originally Posted by z31freakify
Do all pf them with that many miles they need to be changed.
what is PF? wish i know the condition of mine without having to take them out. Well it runs..
Old 05-21-2016, 03:35 AM
dylansf23's Avatar
dylansf23
In the process of doing mine and wow. It's a pain. Not that bad, but there's no way to tell which ones are the bad ones. All the ones I've seen in videos are COVERED. In oil. Well my oil is clear. Had one that was more diesel smell but I also had stepped away for a good bit so it might have just been fresh smell. Stopped for the night. Woo.
Old 05-21-2016, 12:23 PM
dylansf23's Avatar
dylansf23
Two injectors (passenger side front two, so far) look like that. Hats a new cup needed isn't it?
And then the other ones with the chips missing have been sporadic as far as which one it is. I didn't write that down because if they need replaced(in a hurry) I'm gonna do them all. They are original.
Pictures won't load. The one has little chips or cracks in the injector below the solenoid section. In the hard metal. Not the black
The other has a sludge that's red around the end. Not the tip that sticks in the combustion chamber, the part immediately after the copper washer.
Old 05-21-2016, 01:12 PM
knottyrope's Avatar
knottyrope
Fun stuff. I'm about to dig in to mine and see what's going on. I have two that are knocking bad, one each side. Pass side cover is off already and rain is holding off so far.
Old 05-22-2016, 10:08 AM
dylansf23's Avatar
dylansf23
The first two I assume is some sideways wear? Loose cup?
Second is that sludge.
Third is the damage.
Over all it wasn't that bad of a project. Having done it now, I'm not scared to do it anymore.
That squeak is gone, and I can hit full rom and I even have better boost! I can hear it now lol.
After I made sure she wasn't gonna die on me. About two miles out is a 70mph highway, so I gave her good gas and pulled through third shifting high and when I looked back the night had turned colors and the cars had faded lights. First time she's ever rolled a significant amount of coal!(sure it had something to do with all the **** in the system from pulling them.
I recommend the rag truck. Pull the injector out, stuff a rag in. Clean swap orings pull the rag out make sure insides clean and stuff the injector back in.
Then once it's all done, pull glow plugs, spin the engine by hand a few times (15/16) then put valve covers back on and use the starter to spin a few times and throw it back together. It took me about an hour and half to finish it after I had the valve covers on. Crank and crank and crank then wait. My starter is a year old, and I'm not doing that again.
  #28
Old 05-22-2016, 10:12 AM
dylansf23's Avatar
dylansf23
  #29
Old 05-23-2016, 10:33 AM
nossliw's Avatar
nossliw
nossliw is offline
Just an FYI the Black Green ring combo is where your oil was bypassing into the fuel. Appears yo lower washers were not sealing properly as well to the bottom of the cup.
I wire brush the cups and carb clean them prior to re oiling the rings and installing the injector... vac each cylinder of any carb cleaner, and crank for a few cycles of 10-15 seconds and then put it back together. Its important to get old ring material and junk out of the cups....
http://www.ebay.com/itm/like/301710712802?lpid=82&chn=ps&ul_noapp=true
  #30
Old 05-23-2016, 11:18 AM
dylansf23's Avatar
dylansf23
Yeah. I'm not sure if the cups are bad or not, the squeak came back some, but more so when it's cold vs warm.
I used a scuffing pad for paint to clean them. Wasn't too sure about the severity of a little scruff on them so I played it safe.
I didn't vacuum it, but I turned it by hand a few times then pulled the glow plugs and spun it a few seconds a couple of times with the valve covers on and didn't have much on them. I didn't fill the oil rail or even touch my hpop, but it only took about six to eight times cranking.
In hindsight it was pretty easy, just very thorough.
gonnasellit
05-26-2017 06:02 PM
sonofdixie
18
04-11-2015 06:37 AM
Tucson F-250 PSD
13
07-26-2012 10:01 PM
Roadgrinder
63
05-06-2009 01:53 PM
sizematterz
12-12-2005 11:37 PM
Quick Reply: Odd issue
