Truck stoped moving
Truck stoped moving
Hi all update it is a 2002 explorer EB 4.0L 4X4 this is the one that ran bad no codes but turned out to be bad gas as it sat for almost 2 years so got it started then the starter went replaced that yesterday drove it today driving down the street the truck just stopped moving like the trany went but when to put in park heard the tranny grind had to turn off eng then put in park but the truck still moved like it was in nutral and when restarted made some clanking noises just want to see what it might be before i go ripping things apart thanks in advance
New update truck did it again was driving and it started to wine drove slow drop child off at school pulling out of parking lot the truck just dropped into 4x4 low all by it's self stopped right there put truck in nutral and pushed the auto 4 wheel and now the truck don't move just like before when the other transfer case cook a dump but no sounds like things broke towed to tranny shop and see where it go's but the 4x4 low light is on and blinking and yesterday the 4x4 high light came on and off by it self and when turning in lot it felt like the 4x4 was kicking in and out and banging any ideas would be great thanks
It seems like I read something about that on here before. You might want to search the forum for something like "disable auto 4WD" and see if you find anything conclusive.
Also, make sure all 4 tires are the same size, the tread wear is comparable, and they are properly inflated per the door sticker.
-Rod
-Rod
ok update took to tranny shop again but this time it stayed locked in 4w low it seems like the transfer case control moduale wants to keep shifting the transfer case from 2w high to 4w high and low for some reason so after 2 hours of working on it this is what they came up with found the wires for the 2w high to put transfer case in and then got it to go into 2w high or the auto and then pulled the plug on the transfer case so the CM can't shift it again so far so good and will get a CM in the near future. want to thank shorod (Rod) for all his help also going to replace the buttons for the 4w drive just in case
it was happening on both transfer cases so i think i will try the transfer case module see what happens but now when i start the truck the message center is bright and can see everything but after a few min's it go's dime almost out and can't really see it anymore any ideas on that? thanks
On the message center, that sounds like either an issue with the interior light dimmer circuit (not likely since you don't mention the radio or anything else dimming) or an issue with a bad solder joint for the message center fluorescent display. It's probably a rather simple fix if you're good with a soldering iron. The most difficult part is probably getting the instrument cluster out of the dash.
-Rod
-Rod
Scott598
06-02-2013 07:11 PM
jimjoebob99
12-01-2009 06:46 AM
fordtrucklover94
20
02-23-2006 08:29 PM
