Help! 2000 Expy won't start.
I'm pretty green at this. Guess I'll search voltage drop test. Would the fuse links stop all power to everything??
Hang on a sec here...
Starter power is a straight line from battery positive, same with Starter relay terminal 30. Starter relay terminal 85 is from the ignition switch and goes through the main fuse box.
Pull the wire off starter relay 85 (the small wire) and see if it reads 12v when you put the key to start. If it reads fine, your cables are suspect. Not a big surprize if they're the original Ford factory crimped ones. Do yourself a favor and solder new ones yourself
He said he had no power, including lights, etc - "NOTHING" was the exact description used.
Except for the main power feed to the starter motor, ALL power for EVERYTHING else has to go through the fuse links. Checking the small terminal in START is a moot point since NOTHING has power, assuming that's actually the case.
BTW, I learned a long time ago that just because something "looked" good does not mean it actually is good.
He said he had no power, including lights, etc - "NOTHING" was the exact description used.Except for the main power feed to the starter motor, ALL power for EVERYTHING else has to go through the fuse links. Checking the small terminal in START is a moot point since NOTHING has power, assuming that's actually the case.
Situations like this are why I keep a multimeter in my truck. My rule of thumb is that if it reads more than 0.6 ohms, it is bad. This is how I diagnosed corrosion inside the trailer battery charge wiring's insulation., it read a scary 2000+ ohms. When i cut it, all that was there was the blue powder called copper oxide.
When checking the starter relay trigger wire, observe if any of the same circuits fall off like before. If they do, follow Project SHO's advice. If not, examine the starter and cables. I suspect a bad cable.
Rattlesnakebyte
Electrical Systems/Wiring
01-29-2016 09:52 PM
babstinger
1997-2006 Expedition & Navigator
09-06-2010 06:44 PM
