[Tech] Alternator & Charging System Checks
Old 05-15-2016, 09:41 AM
Tedster9's Avatar
Tedster9
Tedster9 is offline
Lights flickering getting bright/dim in line with RPM means a voltage regulation problem by definition. You want to fix something like that right away. Testing voltages on the truck is easier than alternator removal.
Alternator & Charging System Checks (Alternator Testing)
Old 05-17-2016, 01:20 AM
Stewart_H's Avatar
Stewart_H
Stewart_H is offline
Post copied to its own stand-alone thread.
Stewart
Old 05-17-2016, 01:30 AM
Pwrgeek's Avatar
Pwrgeek
Pwrgeek is offline
http://www.aa1car.com/library/charging_checks.htm
Could also indicate overloading. If the system is overloaded then the lights will get bright and dim with rpm as the alternator is more able to meet the load. A DC clamp on ammeter is your friend. It'll tell you right away what the alternator is putting out. Between that and a decent sized inverter plus a hair dryer you can put the system under load and do a battery of tests that is much better than anything autozone is going to do after you go to all the work of pulling it.
gman97005
Electrical Systems/Wiring
10-28-2013 10:58 PM
mstiles19
1999 to 2016 Super Duty
15
04-11-2010 01:23 PM
blowhole
03-16-2010 10:57 AM
2003F-350SuperDty5.4
Modular V8 (4.6L, 5.4L)
12-04-2008 06:41 AM
Redneckerson
04-02-2002 12:19 PM
Quick Reply: [Tech] Alternator & Charging System Checks
