Newbie Needs Water Pump
Hello all, I'm Howard, I'm a new "Fridge" owner, and I need a support group for my new addiction
I have a 58 F100 with 292 and 3 on the tree. I am very surprised at the availability of most of what I have needed so far. The snag I have come to is locating a water pump with 3/4" bearing shaft (at least that's what it measures where the pulley slides over). Many places have the 5/8" shaft but none can get the 3/4. Is this an odd ball thing? Would the 5/8" work if I can find a pulley for it?
Thanks for any support you can offer.
By the way, anyone else located in upstate NY?
Last edited by Sparkplugless; 05-16-2016 at 10:37 AM. Reason: forgot to put year & engine
There are water pump rebuild kits available through the usual suspects.
Here's one for trucks?
http://www.ebay.com/ulk/itm/281994563306
Ford Customline Fairlane Thunderbird F100 Water Pump 272 292 312 V8 Y Block | eBay
The car one: A1 Cardone Remanufactured Water Pumps 58-235 - Free Shipping on Orders Over $99 at Summit Racing
I think this is the truck version. I suggest calling them. It used to be part AAZ-58-234, but it doesn't show up.
Cardone Select New Water Pumps 55-21110 - Free Shipping on Orders Over $99 at Summit Racing
An old post from Number Dummy:
Be aware of what you are buying, most ebay sellers haven't a single clue what parts fit.
For example, cars use a different Y block water pump than the trucks.
1954 truck 239/256 Y block pump (EAT-8501-B) is 1954 only. 1955 239/256 pump (B6T-8501-B) is the same as 1956 272 H/D.
1957/61 272/292 C Series Tilt Cabs use a specific water pump (B7T-8501-A).
B6C-8501-B .. Y Block Water Pump / Obsolete
1956/60 F100/600 272 M/D / 1957/64 F100/700 292 / 1962/64 292 C Series Tilt Cabs.
__________________
Bill / Retired Ford Parts Manager / SoCal Chapter Member / Part number research: 1928/2001 trucks & 1928/89 passenger cars.
2015 F150 XLT 2WD Super Crew
__________________
Yep. Btw, when you discover your crankshaft damper is lunched (nod your head "yes") guess where the ONLY manufacturer for Y block dampers is located?
I don't get it either, for some reason the Y block truck water pumps are hard to source.
I did a quick search for B6C-8501-B and located two possible sources.
Green Sales Company, Cincinnatti, Ohio, 513-294-8385 reports 4 in stock. Green handles a lot of obsolete Ford parts. I have not used them but they are pretty well known.
Collectors Auto Supply, Oroville, Washington, 800-414-4462 reports 1 in stock.
Hope that helps,
Lou Manglass
Hope that helps,
Lou Manglass
Hope that helps,
Lou Manglass
Hope that helps,
Lou Manglass
I'm N of Ithaca. Used to drag race at Utica-Rome Speedway. There is anothe Fridge owner (Steve) AKA spurredon near Norwich.
