Hard shift from park
Old 05-16-2016, 07:41 AM
GCLL's Avatar
GCLL
GCLL is offline
2011, 69,000 miles. My truck is experiencing very hard shifts from park to drive or park to reverse after a cold soak. It goes away once warmed up. I can't find any excessive driveline play and my transmission fluid level appears fine and in good condition. Any ideas?
The last repair done on my truck was around 7,000 miles ago and it was for a transmission fluid leak around the bell housing. They just replaced the seal between the torque converter and transmission.
Old 05-16-2016, 12:29 PM
Ferguson65's Avatar
Ferguson65
Ferguson65 is offline
Have you had the truck since new? My 13 always does this as does my buddies 11. To stop it I put the truck in neutral, set park brake, release brakes, move shifter to park. Comes out easy every time. It seems that even if you are on flat ground these things come out of park hard unless you let the park brake take the weight.
Old 05-16-2016, 12:32 PM
GCLL's Avatar
GCLL
GCLL is offline
Yes, I have had it since new and it just started this. It went into drive so hard this morning that it lurched the truck forward.
Old 05-16-2016, 07:10 PM
onebadgt's Avatar
onebadgt
onebadgt is offline
Ouch that is a rough sound to. Mine only does it under load such as a slope.
Old 05-17-2016, 11:27 AM
capt caper's Avatar
capt caper
capt caper is offline
Check to see at your dealer if the solonoids were done. Also if you have the latest flash. .
The 2011 had those issues. ..or you may have torque converter issue.
Old 05-18-2016, 10:24 PM
Dakster's Avatar
Dakster
Dakster is offline
I'm with capt caper - sounds like solenoids could be an issue.
It is a tough shift if you are on grade when you put it into park with the parking brake. But it's more rough sounding than rough acting.
Old 05-18-2016, 10:27 PM
GCLL's Avatar
GCLL
GCLL is offline
Are the solonoids difficult to replace?
Old 05-18-2016, 10:28 PM
Dakster's Avatar
Dakster
Dakster is offline
I can't answer that... I've never done them.
Old 05-19-2016, 06:29 AM
ruschejj's Avatar
ruschejj
ruschejj is offline
No. I've seen pictures that show the solenoids. Looks like you drain the trans fluid, pull the bottom cover off, and the solenoids are right there on the bottom of the transmission. There are probably 7 of them and I don't know anything more than that.
Old 05-19-2016, 06:32 AM
GCLL's Avatar
GCLL
GCLL is offline
Thank you for the info.
Old 05-19-2016, 05:07 PM
capt caper's Avatar
capt caper
Not really..but you still have to have it reflashed from what I read. I thought I read some were on this forum or another how to do it.
Old 05-19-2016, 06:18 PM
Dakster's Avatar
Dakster
Dakster is offline
I'm almost surprised you don't need IDS to change a bulb in the truck. It seems like for everything else that you used to just swap out needs to be programmed.
Old 05-21-2016, 05:58 AM
ruschejj's Avatar
ruschejj
ruschejj is offline
Is it like the old tower computers where any component had to be "registered" or programmed with an "address" to the mother board?
So, the truck is its own closed Internet, where every component has an address so that the main computer can "handshake" all the components?
Old 05-21-2016, 04:01 PM
Dakster's Avatar
Dakster
Dakster is offline
That sounds like a good analogy... Although at least I could build my own tower myself and I didn't need another very expensive computer as the tool to do it. The newer cars that network isn't as closed as we like to think it is.
nxtdiesel
2017+ Super Duty
16
06-27-2019 12:37 AM
WhëëlMå1
6.7L Power Stroke Diesel
16
08-14-2014 12:53 PM
seattle smitty
11-18-2012 04:13 PM
mikeinganges
Aerostar
09-10-2011 12:25 PM
MPlayer
09-03-2008 09:00 AM
Quick Reply: Hard shift from park
