1991 F-150 started blowing white smoke
Old 05-16-2016, 07:00 AM
SkoalDipperJoe's Avatar
SkoalDipperJoe
SkoalDipperJoe is offline
Ok so I was coming back from the store yesterday and I started passing this other vehicle and had to speed up to 70-75mph to do so. I noticed at 70mph my truck would start rolling white smoke out the back. As soon as I dropped below 70 though it stopped then going back to 70 resumed the smoking. Any reasons?
Old 05-16-2016, 08:33 AM
Thedonk's Avatar
Thedonk
Thedonk is offline
is oil level normal?
Old 05-16-2016, 08:36 AM
SkoalDipperJoe
Yeah I just checked it and it was fine
Old 05-16-2016, 09:35 AM
GoinBoarding's Avatar
GoinBoarding
GoinBoarding is offline
White smoke is usually coolant burning. Has a pretty distinct smell.
Old 05-16-2016, 09:37 AM
SkoalDipperJoe
Couldn't smell anything going 70mph with them windows down. That's what getting me. White smoke at 70mph is all I have to go off of
Old 05-16-2016, 09:55 AM
Mike1's Avatar
Mike1
Mike1 is online now
Do a pressure test on you coolant system, could be a blown gasket on manifold or head, or even worse, you could be cracked. It's odd that it's only happening a 70 mph, but this would indicate also that it's building pressure up. check your oil of coolant and your coolant for oil, pull your plugs and see if any of your cylinders are cleaner than the others, look at your plugs and see if any of them are white or grayish color. hopefully it's something simple and not a blown gasket.
magner101
2004 - 2008 F150
05-16-2011 08:55 AM
jkilduff
1997 - 2003 F150
05-27-2010 05:15 PM
rednek01
6.4L Power Stroke Diesel
32
11-29-2007 09:57 PM
RangerRider460
01-16-2005 02:06 PM
ceprice
4 Cylinder Engines
09-28-2004 09:13 PM
Quick Reply: 1991 F-150 started blowing white smoke
