Lol. I'm telling you there is ficm sync when it dies. Ficm voltage is good. All 3. Wonder maybe a short somewhere. Weirdest thing I've seen. 200 or so rpm while cranking, oil pressure,fuel pressure.
ICP volts is zero during cranking... needs to be around 1.0v or higher. It also reads zero with KOEO and should be .18-.24. Have you checked it for oil in the connector or tried unplugged and see what happens?
But im sure you thought about it already but just cause the FICM reads good voltage it can be Bad
A noid light would verify its trying to fire each inject
So its starts morning and will idle till you rev it up a little?? then its done for rest of day
what does ICP show during a crank no start with it plugged in
Yea changed ficm's still the same. Really haven't read icp while plugged in. I'll plug it in the morning and check. Figured it shouldn't matter as long as it was unplugged. But yea, first thing in the morning crank right up, smoke white some don't even have to Rev it, it will die in about a minute. House burnt down do too a faulty outlet. Had a fan plugged in drying carpets and started about 1 a.m in the morning. Luckily we all got out safe.
