1949 Merc engine external oil line diameter
I'm installing a stock oil filter system on a 1949 Mercury engine (going in my 50 Ford F1 pickup). The original oil lines from the block to the filter canister to the block are long gone. I hit NAPA yesterday for fittings and such and the only size line that they had was 1/4". Is this sufficient in diameter. I know that the inlet side fitting is .040" and the internal canister ports are around the same diameter. Will 1/4" line allow sufficient volume of oil flow?
Thanks in advance for your help!!
tvanleeuwen
03-31-2009 08:09 PM
1979ford
08-17-2005 11:17 PM
