Replacement Radiator woes
I purchased a copper/brass 3-row radiator from Performance Radiators for my restore project. I have a '79 F150 regular cab 4x4 with a 400. It dropped into place and mounted nicely to the radiator core support. Only problem is, the outlet tube at the bottom doesn't curve upward slightly like the original. This is causing a problem because the lower radiator hose won't slide onto the outlet tube due to the close proximity of the truck's crossmember. I've taken some pics of both the new installed radiator and the old. I really like this radiator and it appears to be quality. Does anyone have some radiator expertise they could share with me? Is there a shorty hose that could slip onto the outlet tube and angle upward and then somehow couple to a radiator hose? Can the outlet tube be cut and welded by a radiator shop to angle upward, avoiding the crossmember? Looking for a solution to avoid returning the radiator because I'm not sure I'll find one anyway that is designed like the original.
New Radiator
Old radiator with outlet tube angled upward
New Radiator
I'm going to call them tomorrow...business hours weren't working in my favor yesterday when I discovered the problem. I'm not sure how that detail was missed when everything else about the radiator works perfectly. The new radiator would work perfectly in a 2 wheel version of my truck.
I am of the belief that a brand new part shouldn't have to be heavily modified just to make it work right. That is unless of course it is sold or you are buying it with the need or intent to do so already established prior to purchase.
I say send it back and get a champion radiator that will sit farther forward into the core support giving you some much needed room to work.
Like so:
Like so:
FWIW I ran a 3 core copper/brass replacement from AZ for a while. Fit fine but couldn't quite keep up on a hard pull. I replaced it with a 4 core Champion. It fit fine and handles the hard pulls much better.
I suggest return it for exchange for one with correct angle or better yet return it and get a Champion. Avoid the Micky Mouse on the hose.
You should post the part number of that radiator here. https://www.ford-trucks.com/forums/1...endations.html
Never mind. I see that champion only makes the wider radiators for these trucks.
I will poke around the link you provided first to see if its not there already.
I certainly can appreciate squeezing every last pennys worth of use out of anything but if repairing brittle old metal gets old... The proof it works is in the pic I posted.
I don't think it's a matter of saving money. Re-coring a radiator is usually expensive. Like fast hauler, I have also had some aftermarket radiators for various vehicles and equipment that don't fit well or begin to leak within a couple of years. Re-coring the original is a really good way of ensuring that you have a good radiator that fits well. A good radiator shop will examine the tanks and tell you if they are in suitable condition to be used for a re-core. I actually prefer to have radiators re-cored and I have never had a re-cored radiator fail. I have also never bought a Champion radiator so I can't comment on that one--yours does look good and your pictures show it well. If I was to buy another aftermarket radiator, I would likely buy a Champion.
