MPG while Towing 7.7mpg
I just pulled my camper 4400lbs dry weight around 100 miles got 7.7mpg with 3.73 gears truck has 3500 miles I expected to get a lot better mpg. The truck was shifting down to 3rd up hills and they were not bad hills. I tried Manual but I did not like it. Tried Tow haul but felt like I did not need it then just set cruise at 70 in Drive.
I think I need to find best method
Does this sound correct?
here is a post from 2 days ago.... same subject on here in the 6.2L area.
https://www.ford-trucks.com/forums/1...g-mileage.html
the short list.. New Truck, going 70, you have 20's ?
Received 6,677 Likes
on
Mostly just slow down as those (probably) ST tires wont like higher speeds. Also, in the hills, cruise control will ruin gas/fuel mileage as it will try to maintain your set speed instead of you anticipating hills and slowing a bit as you go further up the incline and then will shift accordingly down gears and way up on the rpm. I use cruise only on flat runs.As far as T/H - it changes the gear shift programming and may or may not be beneficial though the hill speed control is fine. It did a great job on my '06 V10 gas truck, not much on the current diesel powered truck. MPG - the V10 was 7-9, the diesel, 10-13.
Few things
1. Use Tow Haul
2. 4400lbs dry? Where did you get that number? Was the trailer actually dry? My trailers advertised dry weight is 7700#, empty it actually weighs 8200# and ready to camp it's 12,???lbs.
3. Everyone is right about the speed. Towing 60-65mph I get 9-10mpg, at 70-75mph I get 6-7mpg.
1. Use Tow Haul
Originally Posted by glockholiday
Few things
1. Use Tow Haul
1. Use Tow Haul
Next trip I will use TH mode and see if that helps.
The yellow stickers on some trailers are way off. My Springdale said #4800 when I bought it, I was pulling the first year with a 4.6 F150 so I had the trailer weighed to actually know what my weight was from the factory. Guess what it came in at a hair over #5200. That was about 10% difference.
trailer weight tags.. lie....
my trailer has 2 tags.. both 7,500 pounds... 2 different Cat scales say 8,300 pounds.
good thing I have a F 250 with a 6.2L
and Yes, 3:73 can do it.. but 4:30 would be better.
fyi, my last trip.. truck, motorcycle, trailer is 17,000 total pounds and I averaged 9 mpg over 2,000 miles
You can use a ScanGauge ll and calibrate that instead of a trip to the dealer. My truck with a bit taller tires is now more accurate and the speedo, GPS and the ScanGauge are all now the same
