Clearance radiator to AC condenser? - Ford Truck Enthusiasts Forums
Old 05-14-2016, 12:31 PM
tractormanbill's Avatar
tractormanbill tractormanbill is offline
tractorman
tractormanbill has a great reputation on FTE.tractormanbill has a great reputation on FTE.tractormanbill has a great reputation on FTE.tractormanbill has a great reputation on FTE.tractormanbill has a great reputation on FTE.
Does anybody have any reliable information on how much clearance there should be between the radiator and the AC condenser? I think I heard someone mention that on overheating you should give more space between the two.
I have about 1/2" and have not had it on the road yet to get a good check on running temperature.
TractormanBill
Old 05-14-2016, 03:31 PM
52 Merc's Avatar
52 Merc 52 Merc is offline
52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of
1/2" between is fine. The closer they are, the better the fan will pull air through both of them together. Too far apart and the condenser becomes an air block, creates turbulence in between, which reduces air flow.
Old 05-14-2016, 10:50 PM
38 coupe's Avatar
38 coupe 38 coupe is offline
38 coupe has a great reputation on FTE.38 coupe has a great reputation on FTE.38 coupe has a great reputation on FTE.38 coupe has a great reputation on FTE.38 coupe has a great reputation on FTE.
My experience is opposite of Wayne's. I have the condenser right up against the radiator in my 53 sedan. It block air and runs hot. A local club member has a 41 Mercury sedan with stock flathead and AC. When he first built the car he had the condenser up near the radiator and his car ran hot. He moved the condenser several inches forward of the radiator and added an electric fan. The engine now runs cool.
Old 05-15-2016, 06:12 PM
bjmayberry2's Avatar
bjmayberry2 bjmayberry2 is online now
bjmayberry2 has much to be proud ofbjmayberry2 has much to be proud ofbjmayberry2 has much to be proud ofbjmayberry2 has much to be proud ofbjmayberry2 has much to be proud ofbjmayberry2 has much to be proud ofbjmayberry2 has much to be proud ofbjmayberry2 has much to be proud ofbjmayberry2 has much to be proud of
Here's what vintage air says (page 3) http://www.vintageair.com/DownloadsS...2806)-Inet.pdf
Old 05-15-2016, 06:39 PM
tractorman
Thanks I should have looked since I have a Vintageair and I installed it.
TractormanBill
Old 10-12-2016, 05:14 PM
johnson.jeff.a's Avatar
johnson.jeff.a johnson.jeff.a is offline
johnson.jeff.a is starting off with a positive reputation.
Closely related. 55 f100, I would like to keep the cross-braces in the radiator horseshoe. If I mount the condenser to the cross-braces, I will have quite a bit more than the 3/16" space between that va recommends.
I've seen reference in other posts that some do install the condenser to the cross-braces... but I haven't seen any pros/cons. Cause over-heating, bad A/C function, clearance issues with grill, etc?
Old 10-13-2016, 09:57 AM
Mr. Ed Mr. Ed is offline
Mr. Ed is gaining momentum as a positive member of FTE.Mr. Ed is gaining momentum as a positive member of FTE.
The reasoning behind the space is the fin spacing on the condenser and the radiator. If they happened to be the same (which they rarely are) you could put them closer together and align the fins. Since they do not have the same fin spacing, the air actually gets blocked if the condenser is mounted directly to the radiator.
Later!
Mr. Ed
1952 truck tags OK'ed for current use in Texas tractormanbill 1948 - 1956 F1, F100 & Larger F-Series Trucks 17 05-16-2016 08:03 PM
Antifreeze question tractormanbill 1948 - 1956 F1, F100 & Larger F-Series Trucks 4 02-22-2015 07:28 PM
"Tech: I built my AC hoses with E-Z Clip System tractormanbill 1948 - 1956 F1, F100 & Larger F-Series Trucks 32 02-14-2015 01:17 PM
Pros & Cons of radiator recovery tank? tractormanbill 1948 - 1956 F1, F100 & Larger F-Series Trucks 6 10-02-2014 01:58 PM
What to do with stock running 52 F-6 with V8 tractormanbill Texas Chapter 4 08-26-2014 12:53 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
