carburetor identification - Ford Truck Enthusiasts Forums
Old 05-14-2016, 04:53 AM
Eddy Sancezz's Avatar
Eddy Sancezz Eddy Sancezz is offline
Eddy Sancezz is starting off with a positive reputation.
hy
i have problems with my carburetor!
he is leaking! I search in vain a number where I can identify him, so that I can order a repair kit!
from the number that you see, I have not become smart.
Does somebody has any idea?
Old 05-14-2016, 07:31 AM
52 Merc's Avatar
52 Merc 52 Merc is offline
52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of
That looks like your typical Ford 2100 2 barrel carburetor. Ford used that carb about forever from the 50's thru the 70's. Finding parts shouldn't be a problem.
Old 05-14-2016, 08:23 AM
thanks for the info
Old 05-14-2016, 09:33 AM
Glxy66 Glxy66 is offline
Glxy66 is starting off with a positive reputation.
If you have a NAPA store close by ask for an Echlin 2-5585 and see what happens. There should be enough of a number stamped into the side of the base towards the front on the throttle side close to the front bolt hole to correctly identify it.
Old 05-14-2016, 09:23 PM
Jules The Great Jules The Great is online now
Jules The Great is gaining momentum as a positive member of FTE.Jules The Great is gaining momentum as a positive member of FTE.
Eddy, sorry I failed you on the wheels.
This is where I have bought my rebuild kits including one for a very similar carburetor to what you have there.
Ford Motorcraft 2100 2150 2 barrel carburetor Parts Page
If you are considering changing the carb I would suggest a motorcraft 2150 with 1.08 venturi's
something like this, I bought one at a local junkyard off a 302 in a 1970's f100 and rebuilt it:
Motorcraft 2100 Jeep Carb Upgrade 258 4 2 Non Smog 1 08 | eBay
The 2150 also came on several Ford cars with a V6.
Old 05-15-2016, 04:27 PM
NumberDummy's Avatar
NumberDummy NumberDummy is online now
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
D4AZ-9A586-A (replaced C2AZ-9A586-B) .. 2100 Series 2V Carburetor Kit (Motorcraft CT-499-D) / Available from Ford & auto parts stores.
Applications: ALL 1962/74 FoMoCo vehicles.
Carburetor Identification Troubles joamariel 1967 - 1972 F-100 & Larger F-Series Trucks 7 10-20-2014 01:29 AM
what Carburetor do i have craigc187 1973 - 1979 F-100 & Larger F-Series Trucks 13 06-22-2011 07:22 AM
Carter ABD pyramid head Fuel Injection, Carburetion & Fuel System 3 07-24-2010 04:46 PM
Carburetor Questions for a 1962 F-100 292 uni62 1961 - 1966 F-100 & Larger F-Series Trucks 1 03-30-2008 05:01 AM
Carburetor Casting Numbers? kooper909 1948 - 1956 F1, F100 & Larger F-Series Trucks 3 06-01-2005 08:23 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
