!996 f350 4x4 7.3 with no wait to start light
howdy yall, i have just bought this truck really cheap, and i got told a story about this truck and what he did, the Guy i got it from told me the was a 20 amp fuse under the hood in the #9 spot blown and he said he changed it but once he turn the key it blown it, so he stuck a 60 amp fuse in it and he said it ran for 4 days, not i got the truck and trying to get it back to running, here is a list i replace, i changed all the glow plugs, glow plugs relay, all the fuel injectors, traces all the wiring, changed some oil presser senser, still no wait to start light, i need help, truck has 253XXX miles on it
My manual calls for a 30 amp fuse for #9, and says it controls the Power Control Module, PCM Power Relay, Electronic Transmission Control, Injector Pressure Regulator, Injector Drive Module. It might be a good idea to check the wiring to the IPR, it might be grounding out, but as Mike pointed out that higher amp fuse might have caused bigger problems.
Mine shoe powertraind moderl
I'm a little drive away from you and not going to be around for a couple weeks. If you're still having trouble when I get back, I might be able to make a trip out of it... I'm not the most experienced guy with these motors but I'm willing to help!
Oh OK, I been trying for a few weeks trying to get it running, where you from
