Really Disappointing 6 MPG towing mileage
My 2016 F250 4x4 with 6.2L and 3.73 gears makes 6.0 mpg towing a 6 x 15' aluminum toy hauler at 70 mph. Toy hauler is 10' high, has tandem axles, and only weighs 3500 lb. All tires are properly inflated, no brake drag, no uneven tire wear. This is in flat country (North Dakota).
Truck has 8500 miles. Empty on highway I get 11.5 mpg with winter gas and 12.5 mpg with summer gas. All numbers are calculated by hand.
I contacted my dealer. His response was since there are no service bulletins on it, there is nothing he can do. Anyone have any suggestions?
This^^
It's not the weight that's getting you, it's the wind. I'm towing just over 12K with a 5'er that reaches 13', and I'm getting 7-7.5 mpg at 60 mph in moderate winds and rolling hills. Even rolling solo, you will see a big difference in mpg driving at 60 vs 70, especially in a gas truck. These trucks are as aerodynamic as a barn turned sideways. Adding a box trailer to the back end only compounds the problem. When I had my 24' enclosed trailer, I NEVER towed it at 70, even empty.
Being in ND myself, some folks reading this may not understand that we call a 30 mph wind up here a gentle breeze. And we don't call it "windy" until it goes above 50 mph winds. It's almost never not "breezy" here. I feel a big hit in my gas tank when that "breeze" turns into a headwind.
Also check your tires. If you're running ST "china bomb" tires (like most trailers), they are likely only rated for 65 mph. Just something to think about as well.
of those air deflector wings on the cab may help to increase mpg. They direct the air up and over the trailer instead of hitting the trailer head on.
I have a 16' boat I pull with my truck that is less than 1000lbs including trailer. Basically no weight but I can tell it is back there on the highway as mpg is reduced. The boat catches tons of air and causes drag. I'd probably pick up at least 1mpg if I put a travel cover on it.
