leaky headers!
leaky headers!
I had to beat and bend the crap out of my headers to get them around the Cordoba steering box. I hear this is a common problem. Can I get them to stop leaking if I can get a bit more torque on the bolts? The hex head bolts that came with the econo headers tend to round off when I try to snug them down. Anyone have success doing this with the ARP bolts with the 12 point head?
looks to me like the stud uses a standard 3/8 nut and that's requires a 7/16 box end wrench and that won't clear the header tube. The far back one won't clear a 3/8 box end wrench so I'm left using the open end wrench and can't get much on that. A 3/8-16 allen head uses a 5/16 allen wrench so I might go that route for the ones that I can't get to with a socket.
I have 2 sets of Felpro. one is thin with foil on one side and they were leaking a lot. The other set is thicker, maybe 0.040" and foil on both sides and those are leaking a lot less.
ARP makes header bolts with a 5/16 or 3/8 hex so you can get a box end wrench or socket on them. If your headers have thin flanges, 1/4" thick steel, as opposed to 3/8" steel or at least 5/16" thick stainless steel it might be difficult to permanently stop leaks. High quality headers typically don't have leak issues.
Ditto, and I have used socket head cap screws in tight locations. If the headers have thin flanges blown out gaskets will be a problem.
I bought some stainless allen head machine screws from the hardware store and will try 'em on the bolt locations that I can't reach with a socket.
