Vibration with AC on
Hi, I have a 2010 F150 Lariat 4x4 with the 5.4. It has around 63,000 miles on it. I purchased this truck last winter and recently have noticed a pretty heavy vibration when the AC is running. It only vibrates when I am at a stop. If I apply a little throttle the vibration seems to go away or it goes away if I shift to neutral. The vibration is not violent but it is above average and I would definitely not consider it normal AC vibration. Any help would be appreciated.
Are you sure you aren't just feeling a drop in the rpms from the air compressor putting a load on the motor? Sometimes the rpms dropping a little low can be described as a rough idle. I think my truck at idle is a little rough because I think the rpms are set low. New spark plugs can sometimes fix your issue.
https://www.ford-trucks.com/forums/1...d-in-gear.html
I had a very similar issue...never solved it, traded truck simply due to high mileage...
Olytlr - Thank you for responding. I am absolutely sure it is not a normal AC vibration. It is a little more aggressive than what I have experienced with other vehicles. It is not violent nor does it feel like the truck is about to stall but it is a good strong shake. If I pop the hood I can see the belt tensioner pulley shake back and forth. I replaced the tensioner pulley a month ago do to the bearings being shot. Maybe I should replace the arm that holds the pulley along with the plugs?
travlnman - Thank you for the link!
An experiment to try , which I did with confusing results. Two people are preferred here. Get it warm by driving a few miles. Park with vehicle running, turn air on, parking brake on, put in D with second person holding foot on brake and see if you get the rough idle/vibration. Then, unplug your connector for the brake lights, and repeat. Mine would not be rough with connector off. I have the Torque App on my phone , and it shows a significant drop in RPM , down to nearly 500, and I felt that with the AC on, it was too much load at this RPM causing rough idle. If I had kept, I would have probably replaced the throttle body...they are a couple hundred bucks on Rock Auto. I replaced belt, pulleys, plugs, etc, etc...with no change.
