1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Air Horn in WNC.
Old 05-10-2016, 07:32 PM
jsw0767's Avatar
jsw0767
jsw0767 is offline
Air Horn in WNC.
Anyone know of a place in WNC to get a set of air horns installed? I remember reading about a place in Asheville but can't recall the name of the place and can't find the old post.
Old 05-10-2016, 09:04 PM
B_A_S_6_9's Avatar
B_A_S_6_9
B_A_S_6_9 is offline
I ordered mine from Hornblasters.com and love the set I got. If you're a handy man, the installation wasn't to bad. Comes with step by step instructions also.
Old 05-11-2016, 07:27 AM
Bigdon68's Avatar
Bigdon68
Bigdon68 is offline
I agree. Got mine from Hornblasters as well and did my own install. Just follow their instructions.
If you do it yourself then the money you save can go towards a bigger system.
bigdon68
Old 05-11-2016, 12:43 PM
jsw0767's Avatar
jsw0767
jsw0767 is offline
Which set did you get and is it as loud as you would like it to be? Also did you mount the compressor and tank in your tool box? Use it to inflate tires? Thanks.
Old 05-11-2016, 04:32 PM
IDI Diesel's Avatar
IDI Diesel
IDI Diesel is offline
This is a hornblaster kit I installed a few months back. I roughly followed theyre install instructions. I used 2 upfitter switches to power the unit, 1 for the solenoid, 1 for the air compressor. I mounted my horns under my aftermarket front bumper. It is very loud!! I use it for the horns and inflating tires on my jeep. I went with the 2.6cfm model with 100% duty cycle.
Old 05-11-2016, 06:56 PM
B_A_S_6_9's Avatar
B_A_S_6_9
I have the Admiral 540 horns. I had the Bullet 127H kit, then upgraded the horns and kept the compressor. No difference in performance, but my compressor is often running. Here's how I have mine set up:
I opted to use the optional toggle switch.
Compressor mounted in the bed.
Horns are mounted under the back right seats. These bad boys are insane. I'll see if I can post screen shots of the DB'S it puts out.
Old 05-13-2016, 01:16 AM
petwofan's Avatar
petwofan
petwofan is offline
Old 05-13-2016, 06:36 AM
RightWingNutJob's Avatar
RightWingNutJob
RightWingNutJob is offline
Thanks for the Video. That's my summer truck project!
I have a pair of Grover, 24", Fire Truck Air Horns that I am going to plumb in.
tom from mass
02-06-2014 09:53 AM
FordmanShane
28
12-17-2010 12:50 AM
drbalazo
10-10-2007 11:14 PM
PowerstrokeJunkie
39
06-03-2007 10:07 PM
JoeBoost
05-28-2003 09:48 PM
Quick Reply: Air Horn in WNC.
