Need help troubleshooting
96 F250 powerstroke 7.3L 201k miles. when out into forward gears stalls out along with going into drive to reverse and vice versa. Had been taken to 3 shops and they can't find anything when hooked to a computer...
It comes and goes tho and has stalled out on me coming to complete stop or slowing down fast.
I would guess it is a short in the wire that goes to the torque converter lockup solenoid.
To test this you could splice a LED light in the grounding wire between the transmission and the PCM then it will light up every time the wire gets grounded. Either by short or by command from PCM.
I would believe that if the light stays on below 35MPH then there is a short.
I don't know about in reverse, but I have had my truck idling in Drive and flipped my switch on and it killed the motor.
Attached is a "how to" PDF.
Kevin
Kevin
mdierking
03-02-2015 07:56 AM
tity(.)(.)stroker
06-15-2006 09:01 AM
tom 400 cfi
01-18-2001 05:51 PM
