4.6 & spark knock - Ford Truck Enthusiasts Forums
4.6 & spark knock
Old 08-14-2003, 09:43 PM
nothingbutford's Avatar
nothingbutford nothingbutford is offline
nothingbutford is starting off with a positive reputation.
4.6 & spark knock
My Granddad has a 1999 Mercury Grand Marquis with the 4.6. He's asked me to scan his car with my scanner and look at it to see if I can figure out what's wrong with it. He says it has spark knock (pinging) which to me means either poor fuel quality, dirty MAF, or carbon buildup. What other things can cause pinging? I would like to find out as much about the problem before I look at the car so I know what to look for. I'm thinking it may be carbon buildup because as a Grandparents' car it NEVER gets driven hard thus the low RPM's. What do you think? Any help is appreciated!
Old 08-16-2003, 12:10 AM
LxMan1's Avatar
LxMan1 LxMan1 is offline
LxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant future
4.6 & spark knock
Sounds about right. Could be a faulty knock sensor or an egr problem. Those would probably throw a code though.
Jimmy
Old 08-16-2003, 06:00 PM
4.6 & spark knock
Thanks for the responce. The engine light is not on so no hard codes have been thrown. I found out about carbon buildup causing pinging by my searches on the board, but I don't remember anyone explaining WHY carbon buildup causes pinging? If someone could explain that I'd really appreciate it! (These things really interest me!)
Old 08-17-2003, 12:50 AM
LxMan1's Avatar
4.6 & spark knock
The carbon in the combustion chamber will get hot spots on it. Eventially, they get hot enough to actually ignite the air/fuel mixture before the spark plug does. What you hear is the flame front from the carbon fired mixture and the spark plug mixture colliding(spelling?) in the cylinder. This is why pinging is called preignition. Removing the carbon, removes the hot spot and the air/fuel mixture is only fired by the plug and no more pinging.
Higher octane fuel helps keep this from happening because the higher the octane, the harder it is to ignite the fuel.
Jimmy
Old 08-17-2003, 11:30 AM
4.6 & spark knock
Thanks for the explanation!
Old 08-18-2003, 09:50 AM
95se5m's Avatar
95se5m 95se5m is offline
95se5m is starting off with a positive reputation.
4.6 & spark knock
What's the best way to clear the carbon in the cyclinders? My wife has a 4.0L 92 explorer that pings like a fiend... I replaced the plugs and wires which helped for a while, but it came back last night on a long drive to and from JFK in NY.
I would like to get this fixed, but I also would like to avoid taring down the entire engine.
Thanks
Old 08-18-2003, 10:03 AM
BrianA's Avatar
BrianA BrianA is offline
BrianA has a great reputation on FTE.BrianA has a great reputation on FTE.BrianA has a great reputation on FTE.BrianA has a great reputation on FTE.
4.6 & spark knock
One other thing carbon deposits does is raise the effective compression ratio. This coupled with the hot-spot problem gives you a two-for-one deal. Not a good deal, huh?
I'd suggest one of the high-end (more costly) fuel system cleaners. Chevron makes a good one, and I believe STP Super Concentrated is good. Other folks might have other suggestions.
2003 Super Duty - V10 - Ping/Spark Knock tjv01excursion Modular V10 (6.8l) 99 10-23-2016 06:48 PM
Cetane Boosters Use or Not? Bigboy99 1999 to 2016 Super Duty 3 04-22-2016 04:49 PM
Carbon buildup on spark plugs dadsutton1 2004 - 2008 F150 6 10-15-2015 08:53 PM
Please help me get my EGR working Fordman18 1973 - 1979 F-100 & Larger F-Series Trucks 17 02-18-2012 04:43 AM
'98 5.4L Pings under acceleration w/o code! Phil056 1997-2006 Expedition & Navigator 13 04-03-2005 01:04 PM
Tags
03, 1996, 2001, 46, 50, carbon, explorer, ford, grand, knock, marquis, mercury, mustang, ping, spark, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
