1956 Emblem Restore - Ford Truck Enthusiasts Forums
1956 Emblem Restore
Old 05-09-2016, 10:18 PM
thomasstemmle's Avatar
thomasstemmle thomasstemmle is offline
thomasstemmle is gaining momentum as a positive member of FTE.
1956 Emblem Restore
hi all, trying to figure out a way to restore the pitted old emblems on the 56. I figure I will carefully sand with a dremel tool, and get it smoothed out the best I can. Then prime and paint with chrome paint. Does anyone have a good solution for the red paint? Does anyone have a paint code or anything for the emblem red? thank you
Old 05-09-2016, 10:35 PM
pholmes350's Avatar
pholmes350 pholmes350 is offline
pholmes350 is starting off with a positive reputation.
I want to try and have mine powder coated after I smooth them out, but they are from a 53 and don't have two colors. Not sure if they can two tone powder coating or not.
Old 05-09-2016, 10:44 PM
Jules The Great Jules The Great is offline
Jules The Great is gaining momentum as a positive member of FTE.Jules The Great is gaining momentum as a positive member of FTE.
With the amount of work and time to fix those ones I would just buy them. I would have to fix mine because they are for an F250 and they don't sell them
Old 05-09-2016, 10:52 PM
abe's Avatar
abe abe is online now
abe has much to be proud ofabe has much to be proud ofabe has much to be proud ofabe has much to be proud ofabe has much to be proud ofabe has much to be proud ofabe has much to be proud ofabe has much to be proud ofabe has much to be proud of
Yup, buy them! You are lucky you don't need F250 or bigger.
Old 05-10-2016, 01:50 PM
My truck is a driver, not a show truck. just looking to make it a good 10 footer. Not looking to drop a couple hundred bucks to replace all the emblems on the truck with new ones.
Old 05-10-2016, 03:28 PM
JakRak's Avatar
JakRak JakRak is offline
JakRak is starting off with a positive reputation.
For the chrome, I've had good results with Duplicolor's Metalcast Silver Anodized Ground Coat. It's meant to be used as a base coat for their semi-transparent "anodized" colors in their Metalcast line, but it looks good by itself as well.
I've also used their standard Chrome paint, and that seems to be a bit smoother.
Sorry I can't help with any suggestions for the correct red.
Quote:
Yep, they can.
PhoenixSpecialtyCoatings.com - Phoenix Specialty Coatings ~ Exceptional Custom Powder Coating
I've heard nothing but good things about Leanna's work. She's well known in Mopar circles, and she can probably tackle any powder job you can throw her way.
Old 05-30-2016, 01:54 PM
CudaChick1968's Avatar
CudaChick1968 CudaChick1968 is offline
CudaChick1968 is starting off with a positive reputation.
Thanks for the vote of confidence JakRak!! :-)
Old 05-30-2016, 08:54 PM
JakRak's Avatar
Quote:
No problem, Leanna! You do some great work, so I'm glad to point people in your direction.
Emblem change out???? SLDNX 1999 to 2016 Super Duty 4 12-18-2016 08:29 PM
Suggestion for repainting emblems SilverTrucker 1973 - 1979 F-100 & Larger F-Series Trucks 9 09-14-2015 02:14 PM
Emblem paint Daddywags 1961 - 1966 F-100 & Larger F-Series Trucks 1 02-08-2015 07:01 PM
Side spears & hood emblem red paint rsmack 1961 - 1966 F-100 & Larger F-Series Trucks 12 04-15-2014 09:29 AM
highboy emblems muscletruck7379 General Automotive Discussion 7 06-15-2004 12:49 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
