Bronco or Toy? Thoughts?
#31
Definitely converted, none of the manufacturers have made 4WD vans. John Smith gave some historical conversion companies. I think Quigley and Sportmobile are the current options (other than doing your own if you want another project!)
#32
I'll be that guy...
I would go with a 90's 80 series, it's essentially Toyotas 1 ton, full floating rear and all, they can be had with factory selectable lockers in both ends, and the power issue is solved by finding one that someone already put the Toyota supercharger on.
I'm a Ford guy for the most part, but for overlanding the closer to stock you stay the better, and the Yota is a good package.
As for a van, I guess we should consider one. But I doubt that will be the popular solution. Anyway, thanks.
#34
#35
I mentioned it briefly before, but another way to add to the storage capacity is an appropriate trailer. The catch is that the trailer needs to be capable of going over all of the trails you intend to drive the Bronco. There are companies making trailers like this, but I built my own a couple decades ago and used it on one overlanding trip (with my wife and our 2 year old son, in a Jeep CJ5, from Minnesota to Colorado, camping in CO for about a week).
The trailer worked really well. I designed it so I could jack-knife it past 90 degrees without hitting anything. It has 30" tires, more ground clearance than the Jeep, and every part on it can take a hit. I used a pintle hitch for more strength and articulation than a ball, but a ball wouldn't be terrible either.
I only made the one trip like that, but it wasn't due to any problem with the trailer. We just decided that we didn't want to drive a CJ5 2000 miles ever again, and wanted a better camper at a base camp instead of overlanding. Although you can put a "car top" tent on top of a trailer and get at least part of the way there.
Bob - That's an interesting idea. Hadn't thought of that approach, but for overlanding it might work. I'll mention it to my son.
By the way, where is that? Looks like around Ouray?
#36
That brings up another point. After I took my overlanding trip in the F-250 a buddy of mine thought it sounded like fun, so he took one in a crew cab long box dually! Before he went (also in the Leadville area) he asked me if I thought he was stupid to try and I told him that as long as he didn't drive into anything he wasn't willing to back out of he'd be fine. He had a lot of fun on his trip, but he did do a lot of backing up! Adding a hitch to the front of the truck might be a good idea if pulling a trailer. You can usually disconnect the trailer and get past it, but if you can't turn the truck around it might be nice to be able to pull the trailer while you back up rather than having to push it.
#37
That's a large chunk of beautiful country. I don't know the area around Leadville, but have spent some time between Buena Vista and Crested, SW of there. Would love to get back up there - maybe with our son and his family. He and I could tackle the tough stuff and we could take easier trips with the girls. (And maybe I'd buy my wife the Trail 90 she misses. Put it in the back of my truck, and meet them there. Bret, are you reading this? )
As I was reading about backing a trailer 1/4 mile I was thinking "put a hitch on the front". And, that fits with my thoughts about a winch - why not put it on a drawbar so it can be removed? Taken off for running around town, or moved to the rear if need be. So, kill two birds with one stone.
#38
With the talk about mounting a hitch on the front, I was reminded of an older Louisiana gentleman, with whom I once worked while in Baton Rouge. He pulled a pleasure boat behind a GMC front wheel drive motorhome. When he arrived at the camp grounds, he would attach the boat to the hitch on the front and drive down the boat launch until the boat was in the water. It was much easier for him to see and maneuver.
Here is something for you and your son, Gary. You have seen it before... remember, it has the very rare power mirror option. Ford Bronco XLT | eBay
And for your wife, although not a Trail 90: http://www.ebay.com/itm/Honda-CT-/36...m=361556132475
#39
#40
A winch hasn't made it to the top of my priority list (aka "budget") yet. But if/when I get one I plan to do a receiver mount. Biggest downside I can see is that they kill approach (or departure) angle, so I'd want to make up something that let me mount it higher and vertical, more in front of the grill, when it wasn't being used. Then it could be put into the receiver in a more normal fashion to be used.
I also feel like a receiver mount wouldn't be as strong as a solid mount, especially in a pull angled more to the side. I think I'd want to use a ****** block and hook the cable back to something more solid on the vehicle to take some of the load off the winch mount in that case. Which gets back to my original comment on winches: they can be dangerous when used by someone who doesn't understand them. If I was setting up a truck for my sons I'd be willing to put a winch on for one, but not for the other. Nothing against that son, he just doesn't think about mechanical stuff enough for me to have confidence that he wouldn't hurt himself (or someone else).
#41
I agree on the approach angle issue, but there's got to be a way around it. Perhaps put the receiver about in the middle of the grille and make the tubing supporting it effectively a skid plate? And, I do agree that a receiver-mounted winch isn't as strong, especially off-line.
As for the safety of a winch, my son nor I have any experience with them. But, I'm not sure he needs one. As I think about it, maybe he doesn't even need one.
#42
Gary , I bought a Double outlet hitch from harbor freight and cut the top hitch tube off the stem. I had the winch plate welded to the top of the stem and mounted an at winch on that.
I ran the wires from the battery back and wired in a disconnect at the hitch.
I can still pull a trailer and drop the tailgate with the winch in place.
It would be easy to make it go front or back of the truck.
The few guys I know that off road carry a boat anchor and shovel.
Get stuck. Dig a hole a few feet in front, drop the anchor, cover the anchor, and winch out. Very useful if no trees are around.
#43
#44
on
Realistically you want a minimum of an 8000lb winch on pretty much any off road rig bigger than a tracker or samurai.
A winch is by far one of the most important parts of an off road rig, all that lift, tires and lockers get you is farther before you get stuck, and much more stuck when you do. A winch is the one modification that gets you unstuck, and still functions even if you don't have the lift, tires or locker.
For an overland rig I would not consider running without one. Heck I even have one on my DD/Tow rig.
#45
Maybe I wasn't clear about my thought to deal with approach angle with a receiver mount winch. I'm thinking about welding a receiver tube to a drawbar at about a 90 degree angle. Put the drawbar in the front receiver and the receiver that's welded to it is pointed up. Then put the winch drawbar down into the vertical receiver (with the bottom of the winch facing toward the grill). That way the winch is mounted higher than normal (up in front of the grill instead of in front of the bumper) and it doesn't stick as far forward either. Then to use it you take the 90 degree piece out and stick the winch directly in the receiver.
As far as needing or not needing a winch, I've never had one and I've always gotten out. I do carry a come-along and a bunch of rope and a tow strap, and I've used that a few times (knowing that a winch would make it easier). And the two times I've gone 'wheeling with someone who had a winch it did end up getting used. So I certainly see how someone who has one would never want to be without one.
But I also just finished watching an episode of "Dirt Every Day" on YouTube where a very experienced 4WD magazine editor was overheating a winch motor and hardly getting his Wagoneer to move (at least in the right direction) in snow. Get a novice who doesn't know what he's doing with a winch in a situation like that and people can get killed. That doesn't mean that all novices should never consider a winch. Some people can keep their cool in a situation like that, some people can make reasonable choices about how and where to apply 8,000 lbs of force (or more with a ****** block). And if you fall in both of those categories a winch is not likely to bite you.
But for me it's just economics. I'd love to have a winch, but I'd also love to have a lot of other things and I've found that I don't need a winch, so it hasn't made the top of the list. Yet.
