5.4 cams over advanced? - Ford Truck Enthusiasts Forums
Old 05-09-2016, 12:43 AM
Dumprat Dumprat is offline
Dumprat is starting off with a positive reputation.
Bought an 09 a month ago, ran fine had a code for KAM memory. I fixed that it needed the stereo replaced. I took it to the dealer for transmission service and now it throws P011,P022, p052a And p052c
The truck went from 16 L/100k to a best of 23 L/100k
Cam phases are tight and quiet. Cps changed, cam sensor, VSS,new solenoids and throttle body cleaned. Runs smooth but lacks power.
What am I missing?
Old 05-09-2016, 08:57 AM
Oh and it has new cats. They were changed under warranty before I bought it.
1990 Ford F150 302 5.0 Low Idle On Cold Startup etmooneyha21 1987 - 1996 F150 & Larger F-Series Trucks 15 03-04-2016 09:57 AM
390 Engine Rebuild/Cam Recommendation Lance Hogan FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 3 04-24-2010 04:39 PM
Engine Warranty Question snagnever 1999 - 2003 7.3L Power Stroke Diesel 6 11-24-2004 03:06 PM
Correct spark plugs for '01 V6 4.0L Ranger? seismojones Ranger & B-Series 2 11-19-2003 07:11 PM
360 Vibration scottlane FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 14 07-06-2003 09:28 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
