Whirring noise coming from under truck
Old 05-07-2016, 10:25 PM
abe's Avatar
abe
abe is offline
One Meadow Green Owner
Received 2,609 Likes on 1,453 Posts
On my new 55 F350 there is a whirring noise when the truck is moving. The noise is there going forward and backward, in gear as well as coasting, truck engine running or not. The noise goes faster as the truck goes faster. It sounds like it is coming from directly below the cab.
My mechanic friend says without looking at the truck that it might be the emergency brake band around the end of the transmission. He said maybe something made a nest in there. I crawled under the truck and looked but saw nothing.
What do you think? Is it the e-brake? Or could it be something else? I guess I will have to put the rear end up on jack stands and run the truck.....
Old 05-07-2016, 11:23 PM
Muppy1840's Avatar
Muppy1840
Muppy1840 is offline
Does it have a pto? I don't understand how it could be making the sound without the engine running though. .
Doug.
Old 05-07-2016, 11:39 PM
abe's Avatar
abe
abe is offline
Doug.
No PTO. Is obviously something in the drive train. Could it be a universal joint in the drive shaft.
Old 05-08-2016, 12:27 AM
Oldb's Avatar
Oldb
Oldb is offline
Abe,
Just a guess, and maybe not a good one, but does the drive shaft have a carrier bearing on your truck?
B
Old 05-08-2016, 01:13 AM
Mervy49's Avatar
Mervy49
Mervy49 is offline
Yup Abe, I'm also thinking "U"joint by the way you describe that sound but Oldb might be on to something if you have that bearing.
Old 05-08-2016, 06:24 AM
fordf348's Avatar
fordf348
fordf348 is offline
Doesn't the drive shaft stop turning when the clutch is disengaged?
Old 05-08-2016, 07:12 AM
bjmayberry2's Avatar
bjmayberry2
bjmayberry2 is offline
Only if your stopped
Old 05-08-2016, 07:41 AM
raytasch's Avatar
raytasch
raytasch is online now
Believe Nothing
Let the truck roll slowly and pull slightly on the e brake handle, see if any change in sound. Could be u joints, driveshaft center bearing, e brake, wheel bearing or in the rear end - differential.
Old 05-08-2016, 08:20 AM
WALFORD'S 56's Avatar
WALFORD'S 56
WALFORD'S 56 is offline
Abe, call Chuck's Trucks for the carrier bearing and u joints. I just bought some and he had really good prices.
Old 05-08-2016, 12:36 PM
abe's Avatar
abe
abe is offline
That is a good idea, Ray, to rule out the e-brake. It's not the rear end differential. The sound is coming from below the cab.
Old 05-08-2016, 03:26 PM
B/B ford's Avatar
B/B ford
B/B ford is offline
Clean & Classy
I just noticed a similar noise coming from my C-6 tranny during a local cruising show. I was pretty sure it was from my parking brakes because I hadn't yet adjusted them after putting in my new rear end.
I put it up on jack stands and started it up and put it in gear and the noise was still there. I got underneath and started tracking the sound and followed it to my rear tail shaft on the tranny. I couldn't see anything obvious so I decided to check the tranny fluid, DUH! I was almost a Qt. low. I added fluid and the noise stopped right away. I test drove the truck and it didn't seem to cause any permanent damage. Hopefully I caught it soon enough.
I hope your problem is just as simple to fix.
Old 05-08-2016, 05:33 PM
1956_F100's Avatar
1956_F100
1956_F100 is offline
U-joints don't make a whirring noise. A worn or bad U-joint makes more of a chirping noise and will change as load and speed varies. Might be a bearing noise, but that's more of a howl. I'm thinking it's a gear noise. Has it always been there? Does it change volume or pitch depending on load and/or speed? Some manual trans just have gear noise, because of the gear design. Especially on larger trucks.
Are you certain its not coming from the rear axle? These bearing noise characteristics are often associated with rear axles. Does it get louder when either accelerating or decelerating? Does it change when going around a turn? A rear axle gear noise will often only occur at particular speeds or range of speeds. Or will change volume when accelerating or decelerating.
Old 05-08-2016, 06:00 PM
Jafo56's Avatar
Jafo56
Jafo56 is offline
Abe for years I had a horrible whining noise in my truck it was annoying and sometimes gut wrenching! Finally after the divorice it was a great quiet and peaceful ride!!!
Old 05-08-2016, 06:48 PM
abe's Avatar
abe
abe is offline
It doesn't get louder when accelerating, it gets faster. It doesn't change going around a turn, well I do not know because I cannot really hear it at higher speeds because of engine noise or it is "spinning" so fast I don't hear it. I think it is coming from right beneath the cab. Or is the noise just coming through the hole where the emergency brake comes through the floor board.
Thank-you, all.
Old 05-08-2016, 07:25 PM
Jules The Great's Avatar
Jules The Great
Jules The Great is offline
Is there oil in the transmission? Un-oiled gears would make noise in all directions and whether or not you have the engine engaged but are moving?
Quick Reply: Whirring noise coming from under truck
