tail light question
I cleaned my old tail light bases and powder coated them chrome and used LED bulbs, Just have to make sure your grounds are super clean. If i did it again I would solder grounds to the base cup and run them back to the frame. Also use a flasher made for LED's. I got my bulbs from https://www.superbrightleds.com/ One of the issues with running LED bulbs in the brake lights showed up when I put the cruise control in, they pull such a small amp that the system would not shut down when you stepped on the brakes, so the fix was to add a relay to that leg to sense the brake light coming on. all works well now and the turn signals front and back and tail lights are nice and bright.
The 1957/60 Styleside bed was also used on some 1961/66 F100/350's, but even though they look similar, 1961/66's used different tail lamp bodies than 1957/60.
2) C1TZ-13211-A (replaced B7C-13211-A) .. Gasket-Tail Lamp Lens to Body / Reproduced
2) B7C-13217-A .. Gasket-Tail Lamp to Pickup Bed / Reproduced
B7C-13434-B .. Right Tail Lamp Body / Obsolete
MCDONALD OBSOLETE PARTS CO. in Rockport IN has 6 = 812-359-4965.
B7C-13435-B .. Left Tail Lamp Body / Obsolete
No Ford dealer or obsolete parts vendor has any.
2) C1TB-13450-D (replaced B7C-13450-A) .. Tail Lamp Lens / B7C-13450-A reproduced by Carpenter.
wrhinehart
24
11-10-2015 06:15 AM
