Various years flathead 239 compatibility
Wishing to go back to a flathead engine in my 51 F1. I have the correct transmission and engine mounts in place. I purchased a bare block on the cheap that came from a 1950 sedan, but it is a tad rough upon further inspection. SO I am perusing craigslist, etc., to see what is out there. I realize that the engines changed a bit over the years from the 40's to early 50's. What I am wondering is, what various flathead types will fit correctly in the 51? I see engines classified as 8BA with RT designation for truck which seem like the "proper" engine, but also older 59 series, etc. How much range in year can I get away with? Also, what about the car versions of the same engine? will they swap in? Seems to me the important thing is the engine mounts/water pumps. Can these be swapped from engine to engine? Basically, I need a general guideline of years, models so that I do not expend a lot of travel time/cash picking up something that wont even fit up right. And yes, I am real new to this engine swap thing. Thanks much for any help/guidance.
The 48-53 model engines, 8BA, 8RT, and EAB can all be made to fit easily. To fit them into the trucks, you need the truck water pumps which have the correct engine mounts built into them. The older engines, like the 59 series and earlier, all which have an integral bell housing cast into the back of the block, are more difficult to use and wouldn't look correct.
You can use a Car engine in your truck, BUT cars from ~'52-on used a different belt system (two narrow belts vs the fat belt that goes around the WP's, generator, and crank), and they used different WP's and motor mounts. If you find a good Car engine you can swap the WP's for truck pieces, swap the crank pulley, and change the generator sheave to use it in a truck.
Are you looking for a drop-in, good running engine? What's "rough" about the one you have?
ALBUQ,
the block has one cracked sleeve, a couple of cracks between the head bolt/water jacket, and pretty chewed up valve seats. Many of the bolt threads also seem to have a lot of slop, not holing bolts. I also am lacking generator, water pumps, distributor, oil pump, etc. Trying to balance what it will cost me to build this one up (even though it was a cheap purchase) compared to finding something more "drop-in-able."
What 52 Merc said!!!!
Water pumps, fan idler and gen are the main diff.
Where are you located in MO?
Merc's are the best, if you can find them, but you still need the correct pumps ect to fit them in your F1.
You'll also need a truck trans to mount everything easily.
I have 2 51's you could look at if you're not too far from the St Louis area. One is an all original F1 and the other has a Merc in it.
THANX RICH
THANX RICH
THANX RICH
THANX RICH
Mercs are 255 cubic inches, Fords are 239, so roughly 6% more c.i. It mainly manifests itself as higher torque down low, actual HP difference is "maybe" 10. If you are boring and replacing pistons anyway, it can make sense to use a stroker crankshaft at the same time. It's about, say, $500 for that 10 HP.
Like 52 Merc said longer stroke of Merc makes more torque.
Torque is a good thing!!!! but not worth a lot of extra cash for what most of us use these vehicles for.
Great for bragging though...
If you ever get up I55 around Festus MO give me an advance heads up and I'd be glad to show you what we're talking about.
THANX RICH
THANX RICH
